SOURCE: Washer keeps displaying '4E' Lack of water error
If you have pulled out and cleaned the filter at the back of the machine where the hose connects then I would check that your pump is not running during the cycle and also make sure your drain line is at least half way above your drum at its highest point, If its too low then it will drain off even if the pump is not running.
SOURCE: Washer Intuitive Fault code 12 Washer keeps
Hello there:
This code is a indication that your water inlet valve has failed and needs to be replaced when these valves fail they will continue to drain water into the machine even if the unit is unplugged
What you can do is to first unplug the machine and turn off the water to the unit then remove the hoses to the machine then youwill need to remove the back panel of the machine so you can get to the water inlet valve once you get to t the valve remove all of the hoses to it and the wiring and remove the valve then you can open up the valve and inspect it and replace any parts that are worn or rusted like seals or seats or simply replacve the entire valve itself this will cost you about 40 to 60 dollars ok once the valve has been repaired or replaced reinstall the water hoses and turn on then plug in the machine and if you have a cancel feature on it press that than you should be good to go from here run a couple of cycles thru it to ensure it is working properly ok
Hope this is very helpful for you
Best regards Michael
