Question about LG Washing Machines
Burning smell during a spin cycle does it need a new belt? LG Front Load Washer WM2487HWMA
  • LG Master
  • 2,529 Answers
There is no belt or pulleys on an LG front loader. Direct drive motor. Burning smell could be bad bearing, bad seal or broken spyder with inner tub rubbing on outer tub. Try wiggling inner tub and see if it moves independently of outer tub. That wouldn't be good. Let us know results of wiggling.
Posted on Jan 18, 2020
    Fixya-Fanatic:
    Visited the website for 90 consecutive days.
  • 360 Answers
Yes, change the pulleys too. You can buy a kit
Posted on Jan 16, 2020
Anonymous
SOURCE:
localwonder
Michael Masters
  • 6784 Answers
SOURCE: Front load Fridgidaire ftfb4000fs1 won't spin
This is a fault that resides within the motor control board. you will need to replace this failed module asap if possible. it has failed.
Posted on Jun 15, 2009
Anonymous
  • 5 Answers
SOURCE: My model #gltr1670aso makes loud noises during spin cycle
Usually this is due to either the drum support breaking or the back bearing being bad-neither easy to fix- or worth it. Try lifting the drum up and down, if it moves up and down they are bad. I see this a lot, and the price of repair isn't worth it. Craig
Posted on Aug 02, 2009
Anonymous
SOURCE: ATF6000ES front load washer won't spin during regular cycle.
clogged filter will cause this error code. I have the same washer and the filter located inside the rubber boot attached to the pump was full of junk. there was enough room for water to get thru but not enough for full volume. clean it out and it should work. note : its a pain to get the boot back on so be ready and take it slow. this worked for me.
Posted on Aug 30, 2009
Toby Gomes
  • 38 Answers
SOURCE: burning smell during spin cycle on frigidaire washing machine
Open lid as you would load clothes and hold the inner drum with all the holes in it. Give it a manual turn left, then right. If it spins in both ways the main bearing is gone. This is not a DIY because the new bearing has to be pressed on at a machine shop, or an appliance repair shop.
Posted on Dec 29, 2009
Anonymous
SOURCE: LG WD-8050FH LOUD noice when spinning & 'funny' burning smell!!
I had the same symptoms and almost dismantled the whole machine to locate the root of the cause. The issue was one of the 3 arms of the spider (like a 3 spoked wheel that connects to the rear of the drum and holds it in place and provides the drive shaft to through to the motor at the rear), had snapped after weakening from corrosion due to undissolved washing powder building up in the grooves.
To prevent this, do a hot wash every few weeks to dissolve the powder, don't think your saving the environment by using only cold washes, this should be in every washing machine manual to save the environment from waste from un-economically repairable appliances.
The burning smell was the unbalanced drum leaning heavily on the rubber shroud on the front between the drum and the outer casing. The replacement spider part was only about AU$60-80.
To check if this is the problem you may be able to tell by opening the door, and reaching in from the front with your palm up about a hand distance till you go past the rubber shroud and just touch the stainless steel drum. Grip it gently with your four fingers and pull towards the front (to you) about 1cm or two, with about as much force you would need to open the machine's door. Rotate the drum approx one third of a rotation and repeat, do this 3 times and you should feel one point give more than the others.
If no luck try again in sixths of a rotation, you can gauge the distance by the 3 plastic agitators attached on the inside wall of the drum.
Note: get a price on labour first to replace the spider, as this will be probably more than half way to a new machine, and then the cost of the part, and the call-out fee if you can't get it into a service centre.
What's the point of having a long lasting stainless steel drum when the key part that connects the drum to the motor is a weak cast iron / alloy part.
Ask your local service person what units have quality parts before buying a new machine.
ps: the loud noise is probably the cracked arm rubbing or the unbalanced drum hitting the sides and making the machine jump.
Hope this all helps!
Posted on Apr 06, 2010
I have a burning smell coming from my LG front load washer. I googled it,it says it's the bearings. Which would be easier? Buying a different drum with bearings already pressed in or doing my own?
Holly, always easier to buy an assembly, but probably a lot more expensive. If you can remove bearing and take to a industrial supplier and get matching bearing, the cost would be a fraction of that of a new drum assy. If you or a friend can do it, go for it.
You may want to get a second opinion on what you are smelling, it very well could be the drum rubbing gasket if it is a burning rubber smell.Maybe call a good appliance Tech. have them diagnose and estimate repair. Check LG washer bearing link below.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
LG washer Burning Smell Service 7o7 4451591
How to Diagnose Drum Problems in Washing Machine
GE Washer Smoking During Spin Cycle
Aug 21, 2016 | LG Washing Machines
LG WM2487*M Washer smells like burning rubber in spin cycle
Smells like, I mean sounds like, a belt is burning either from friction caused by a bad bearing, or, a loose belt is slipping on the pully a bit, causing it to heat up from the friction.
Dec 05, 2013 | LG WM2277H Front Load Washer
The washer is making a very loud noice and i noticed slight smell of burning during cycle! The drum seems very unstable too! Could this be the drive belt? Is this fixable or am i looking at a new...
Sounds like the main drum bearings have failed.
Spin the drum by hand from inside, if it feels rough, or it is noisy or rumbling, then the bearings habve fauiled.
Probably better to buy a new washer.
Nov 09, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Washer has been making an unusual amount of noise / burning smell
remove the door and screws on opposite side and the front comes off. Then the top will flip up.
Eric
Nov 22, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag SAV 3652 AWW Washer: During spin cycle, burning smell occurred while making unusual noise. (For months, major squeaking during agitation).
Bad water pump. Replace water pump.tip machine back,Look under machine, remove belt, turn pump by hand, if not spinning freely replace pump.
Mar 23, 2009 | Maytag PAV2300 Top Load Washer
Very loud final spin cycle with burning rubber smell
Hi Mcbride2
It could be one of 2 things. 1 the belt. or 2 the main seal and bearing. i recomnd to get a tech just to make suer.
brent
Sep 06, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washer smoke during spin cycle...
could be belts slipping or a bad motor going - what's it smell like - burning rubber or an electrical smell?
Aug 28, 2007 | Kenmore 98702 Stacked Washer/Dryer
Washing Machines Logo
122 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
