See this video
https://www.youtube.com/watch?v=ahf2oggp8qY
SOURCE: I have a miller 251 millermatic welder that has no
check the wireing from the gun to the servo,it may have got damaged.then test the servo
SOURCE: I have a millermatic 251
First, you need to check that you have the correct input voltage going to the machine. The main PC board on the welder disperses the input voltage to many different things,ie. the gas solenoid, the drive motors, contactors, transformer, stabilizer etc.
So if your machine is made to run on 230v and it is plugged into 208v, the first thing to stop working is the gas solenoid because it requires more voltage (34vdc on this model) to actuate.
If it turns out you are running the correct power to the machine, there is something wrong with an internal component on the machine and it needs to be brought to a certified miller service center where it will most likely be one of two things, the gas solenoid (about $30+ labor) or the main PC board ($500-600+labor) hope for the best on that one.
best of luck!
