Question about Building Materials
Trying to enter Defiant temporary code. lock lights up red. when I press the keypad nothing happens
    Top Expert:
  • 30,872 Answers
Anonymous
SOURCE:
Anonymous
SOURCE: ERROR CODE
I have tried this, open the notebook from back and remove the CMOS battery and leave it for 12 hours, then boot the system and shutdown immediately and put CMOS battery on its place, then boot the system Junaid Pakistan
Posted on Feb 23, 2007
Anonymous
SOURCE: Blackberry 8310 keypad locked
Use a blowdryer of the keypad for about a minute, some buttons will start to work. Continue until all of the buttons are functional. Works like a charm.
Posted on Dec 20, 2008
ipodslinger
Steve Brown
  • 688 Answers
SOURCE: enter passcode screen is on, unable to enter code, appears frozen
you can fix it by restoring it in iTunes.
Here is a way to put it in recovery mode.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Iphone and itouch dfu mode
Plug the usb cable into the Ipod and NOT into the computer.
Hold the Home Button down for 5 second (do not release it)
Then Press and hold the Power Button for approx 10 secs (count them out)
Your iPod will reboot.
Release the power button and continue holding the Home button for an additional 27secs.
You may see the screen go blank or not.
Plug the USB end into the computer with itunes open.
Your ipod will mount in recovery mode.
Restore it and Your all set.
Posted on Jun 10, 2009
Don Maggard
  • 3197 Answers
SOURCE: Can not program both keypad & remote to operate at the same time
One of your units has reverted from "rolling code" to "billion code" and as you have found they will each work but will not work with each other. The problem is finding out which unit reverted. The most common one is the hand remote but that could be wrong.
Posted on Aug 10, 2009
blanchettohd
robert blanchette
  • 143 Answers
SOURCE: Trying to add temporary code to craftsman keypad for Sears garage door opener.
Yes there is you need to press the colored learn button on the motor head and then follow the directions on the keypad. Thanks BB
Posted on Sep 03, 2010
Set combination for paragon lock & safe
TO SET UP OR CHANGE A USER CODE
1. With the door open, locate the red button on the back of the door near the hinge.
2. Press the red button and listen for the beep.
3. Immediately enter your new pass code (3-6 digits long)
4. Immediately after entering your new pass code, press the "A" or "B" button on the keypad. Your new user pass code is now stored.
NOTE:
This safe stores up to 2 pass codes (a user code and a manager code). Entering a third code will erase the
first pass code entered.
SETTING UP OR CHANGING A MANAGER PASS CODE
1. Open your safe with the pass code you wish to change and leave the door ajar.
2. Press the "0" button on the keypad twice. Press the red button, listen for a beep and then enter your new user pass code.
New user pass codes may be 3-6 digits long.
3. Immediately after entering your new code, press the "A" or "B" button on the keypad. Your user code is now changed.
http://www.paragonlockandsafe.com/manuals/mastermanual.pdf
Aug 29, 2014 | Paragon Electronic Digital Safe Jewelry...
How do i set code for paragon safe
INITIAL BATTERY INSTALLATION
1. Remove the key plate cover, insert the key into the keypad and open the door.
2. Remove the battery cover plate located on the inside of the door.
3. Install 4 AA batteries provided and replace the battery cover.
NOTE
: If both the red and green lights are on while the safe is open, this indicates that the batteries are low and need
to be changed.
3. Immediately enter your new passcode (3-6 digits long)
4. Immediately after entering your new passcode, press the "A" or "B" button on the keypad. Your new user passcode is now stored.
NOTE:
This safe stores up to 2 passcodes (a user code and a manager code). Entering a third code will erase the
first passcode entered.
SETTING UP OR CHANGING A MANAGER PASSCODE
1. Open your safe with the passcode you wish to change and leave the door ajar.
2. Press the "0" button on the keypad twice. Press the red button, listen for a beep and then enter your new user passcode.
New user passcodes may be 3-6 digits long.
OPENING THE SAFE
1. Input your code and then press the "B" button, the green light will turn on.
2. Turn the knob clockwise within 5 seconds to open the door.
3. Each key pressed will be accompanied by a buzzer and a yellow flashing light. If the entered code is invalid the yellow light will
flash and the buzzer will quickly sound, this indicates the code needs to be re-entered.
CAUTION
: Entering the incorrect passcode 3 times will lock the system for 20 seconds.
More information can be found in the attached document web page.
I have a Defiant Electronic deadbolt from home Depot. model G1X2D01. ive lost the manual and i need to delete some old codes from it.
Snap off the back cover (opposite where you punch the numbers) by pinching the sides and pulling off. Do not press a pen or anything into the small light, you do not need too. Just pinch and yank off cover. You will see a small light and beside it is a small SET button by the batteries, it is labelled.. Press this Set button for 2 seconds. The red LED will light on the front code side and beep twice to indicate you are in programming mode. Enter your current code that you want to change (factory set is 12345) and then press the button that looks like a little lock on the keypad. Enter the digits "10" and press the lock button again. Enter the new code (must be six digits) and then press the lock button again. The red light should go on continously for 10 seconds. The code should be effective.
Note: if you have problems like we did, you can also remove one battery and press the "set" button simulataneously when you reinsert the battery. This resets the factory code of 12345. Then you can start over. For some reason our old code was only 4 digits, but it would not let us reprogram a 4 digit code. It didn't work until we did a 6 digit new code.
Apr 15, 2012 | Locks & Locksmithing
Unit is functioning o.k., but getting green light flashes about every 10 seconds. Batteries and connections are o.k.. Can't find anything in the manual or on Weiser website as to a solution.
reset all code and retry...
  1. To program the first code, press the reset button once, then enter your 4-8 digit code on the exterior keypad, then immediately press the middle lock button on the exterior keypad. You will hear a beep. This signals that your code has been accepted.
  2. To program the second code, press the reset button twice , then enter your 4-8 digit code on the exterior keypad, then immediately press the middle lock button on the exterior keypad. You will hear a beep. This signals that your code has been accepted.
  3. To program the third code, press the reset button 3 time, then enter your 4-8 digit code on the exterior keypad, then immediately press the middle lock button on the exterior keypad. You will hear a beep. This signals that your code has been accepted.
Good lock
Good unlock
Dec 31, 2010 | Weiser Lock Powerbolt 1000 Lock
We are trying to reset a security code for our existing weiser lock and it isn't taking the new code entered.
Good lock
Good unlock
Nov 08, 2010 | Weiser Lock Powerbolt 1000 Lock
How to setup temporary passcode
Hi, my name is Randy and I can help you with that. Try this:
  1. Put in you permanent Pin
  2. Hold down the * until the unit blinks 3 times then release the button
  3. Put in new 4 digit "Temporary" Pin
  4. Press "Enter" then the light will blink 4 times
  • If you want to set the number of hours the temporary Pin will work you press the number of hours (up to 255 hours) then press *
  • If you want to set you temporary Pin my how many time it can be entered then put in the number (255 Times the code can be entered) and press #.
You should try your temperary Pin to comfirm that it is set. Remember this will count as one of the uses if you chose to go that route.
Thank you for the chance to help you,
Randy
FixYa Support Team
P.S.
If this helps you, please rate me.
Good Luck...
Oct 06, 2009 | Sears Craftsman LiftMaster Chamberlain...
Temporary passcode
Press the four buttons for your personal entry PIN, then press and hold the * button.
The opener light will blink three times. Release the button.
Press the temporary 4-digit PIN you have chosen, then press Enter.
The opener light will blink four times.
To set the number of hours this temporary PIN will work, press the number of hours (up to 255), then press *.
To set the number of times this temporary PIN will work, press the number of times (up to 255), then press #.
Test by pressing the four buttons for the temporary PIN, then press enter. The door should move. If the temporary PIN was set to a certain number of openings, remember that the test has used up one opening. To clear the temporary password, repeat steps 1-3, setting the number of hours or times to 0 in step 3.
Keypad reset. Now that I have the original keypad code, how do I change the code?
your owner manual tells you. Why not use the original code?
To change, here is 96 procedure, should be the same. please give good rating if this is what you want.
Entry Code The system (permanent) entry code is located in three places:
  • on the owner's wallet code card (in glove compartment)
  • electronically accessible by requesting the remote anti-theft personality module KEYCODE PID on the New Generation Star (NGS) Tester
  • on the remote anti-theft personality module housing
The remote anti-theft personality module is programmed at the factory with a five-digit entry code. A replacement remote anti-theft personality module includes replacement labels and a new owner's code card. To turn on the interior lamps and light all illuminated components:
  • press any button on the keyless entry keypad (14A626).
To program a temporary access code:
  • Enter the permanent code on the keyless entry keypad.
  • Press button 1/2 within 5 seconds of last digit of permanent code. (This alerts system to accept temporary code.)
  • Enter alternate five-digit code. Do not exceed 5 seconds between entering digits or between pressing the 1/2 key and entering the first digit.
Apr 08, 2009 | 1995 Ford Taurus
Building Materials Logo
24 people viewed this question
Top Building Materials Experts
Tom Chichester
Lawrence Oravetz
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
