If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
SOURCE: will not let select the
I suspect that when the television was set up for the first time energy-saving HOME mode was not selected. Rather STORE mode was selected. You will not be able to make certain picture adjustments when it is set up as if it were going to be displayed in a store. You will need to go into the menu and select your language and then press menu again and select HOME mode. Then you should be able to press the LAST button on the remote and menu again to exit if necessary.
SOURCE: i am having a problem with my volume fluctuating
Does this happen on all inputs? Have you tried different devices? I am assuming you have recently purchased this tv new. If the problem happens with all of your devices and on different inputs I would check the stores return policy and return it to the store or have it serviced under the manufacturer warranty. If you need further assistance please let me know. If you find this information helpful please take a moment to accept/rate my solution accordingly.
Thank you,
Lee
Since sensor is receiving the signal of other inputs, there is nothing wrong with it. This looks like an incompatibility issue. You may have to retry using the original remote control.
