Unknown coffee maker described may be a Mr. Coffee model.
https://www.fixya.com/support/t3910986-mr_coffee_beeps_3_times_thats_all_no
SOURCE: it's not brewing the coffeee,
when you hit the button do you here the clicking noise.
if not then the first check that the voltage is going to the solenoid .And also check that solenoid isn't gone bad.If solenoid okay and you find no voltage then replace the switch.
if you didn't see any light then use AC current tester to check that the voltage is comming into the brewer or not.
i will be happy to assist you thank you bye
please rate my work
SOURCE: The blue light on the left doesn't light up.
There is air in the lines and it is blocking the water flow...
Here is a tip that will help you getyour Keurig to prime...
Keurig CoffeeBrewer will not prime
heatman101
SOURCE: KitchenAid Coffee maker KCM111 brand
Sounds like it is broken. Should be under the manufacturer's warranty. Go to the store and get it exchanged. Or contact KitchenAid.
SOURCE: red light comes on but coffee doesn't brew
If there is a thin water line in your coffee maker, then it can get clogged or could have mineral build up. Keurig coffee maker, you are going to want to descale it every 6 months. Calcium can build up.You need to run a large cup of white vinegar through coffee maker lines. When you run vinegar through there, the coffee will taste nasty, so I would run water in there several times, after the vinegar finishes. Run through until does not taste nasty anymore. Yeah, I do this with my coffee pot 3 times a year. You judge how often you should.
Good luck.
SOURCE: mr coffee beeps 3 times and thats all, no brew
I've had this problem for over a year, it seems. Brewing a large cup takes about five or six tries to get it all the way through, and the hot plate turns off so it has to be consumed quickly if you want hot coffee. Two mornings ago, I discovered if I put about a sixteenth-cup of water on the hot plate, the coffee maker looks like a witch's cauldron while it brews, and beeps three times... but does not turn off and will brew a complete pot of coffee and keep it hot. As a safety tip, turn off manually when done!
