When i try to charge it, it will power up just for a sec.
Bad battery
Are you asking about a Harmon Kardon Esquire bluetooth speaker? Your question has posted in the Cell Phones category. I am not familiar with any cell phone with the brand name or model name of "Esquire."
Hello, Pratik -
Best wishes.
SOURCE: My tomtom doesnt turns on.
Remove the micro sd card from your TomTom. Look at the bottom of your unit, where the copper contacts are (where the unit mounts to the windshield mount). You will notice a "cut-out" in the plastic case, just above the contacts. The reset button is there. Use a paper clip and depress this button for 15 seconds. Now press the power button, and it should turn on. Now replace the sd card.
SOURCE: roomba discovery on full charge
unfortunately the batteries on the roombas can go bad and not hold a charge and need to be replaced, also you should check all the brushes and wheels on the bottom, if they are bound up it would stop the roomba from working. the two brush rollers can be removed by pushing on the two tabs just above them, try and clean any hair from them. if its real bad you should buy the maintance kit from them witch gives you both brushes and filters as well.
SOURCE: when i tried to charge
Hi ,
You can try taking out your battery from the laptop and keep it out for 5 min then put it back in , this resests your laptop , this might work , it might not , if not I recommend you take it to the shop for tech support.................... Goodluck Roy
