Check your settings
When your iPhone is locked (the screen is off), Do Not Disturb silences all incoming calls, text message notifications, and alerts on your iPhone. Unlike silent mode, Do Not Disturb sends incoming calls straight to voicemail.
https://www.payetteforward.com/why-does-my-iphone-go-straight-to-voicemail-heres-the-fix/
SOURCE: All my Calls go Straight to Voicemail
Here is a link to the user manual for you
http://www142.nortelnetworks.com/bvdoc/norstarbcm/t7316.pdf
SOURCE: not recieveing incoming calls go straight to voicemail
call cricket cause sometims that would happen to my phone but it was just because they messed up my bill and got it confused with someone elses
SOURCE: calls go straight to voicemail
You please change the setting from answer voicemail to ring mode if you have any dificaltey refer your phone user manual book and reset the option
SOURCE: number of rings before going to voicemail on KX-T7630
Press the FWD/DND button, then scroll through the menu button until the screen shows "FWD No Answer time". Then use the number key pad to change from 000 seconds to 010 seconds (or longer if required). Then exit out of the menu.
SOURCE: phone does not ring goes straight to voicemail
hello, its is possible that you have activated your call DIVERT...
Try to deactive all call DIVERT on your phone device.. Go to your settings, check CALLS SETTINGS, THEN YOU CLICK ON CANCELL ALL DIVERT..
cheers.
