Screenwash reservoir on many modern vehicles is quite large with capacity of a gallon or more and so apart from being heavy it is also bulky and so often is fitted low to improve design and keep the centre of gravity low and so behind the front bumper or underneath a front wing is fairly typical.
The screenwash pump is these days generally fitted in the bottom of the reservoir so the impeller is always wet and maximum pressure is available instantly.
SOURCE: How do replace windshield wiper motor?
Go to http://www.hmaservice.com/ and sign up - it's free. They have detailed instructions for all items.
SOURCE: Windshield Wiper motor replaced, now wipers go wrong direction
This sounds like the park circuit is shorted.
SOURCE: need to know how to replace the windshield wiper motor
First remove the wiper arms.Then remove the screws that hold the black plastic grill, you will see the motor.You will need then to disconnect the wiper arm transmission linkage from the motor, then remove the three bolts holding the motor on, dont't forget to disconnect the electrical connector from the motor.Install in reverse order.Good luck.
SOURCE: 06 cts when you turn wipers on windshield washer
you must replace the multifunction switch its all one unit sorry
SOURCE: How to replace the wiper motor in 1997 Caravan?
YOU NEED A REPAIR MANUAL. ALSO YOU WILL HAVE TO REMOVE COWL COVER WIPER WASHER HOSE AND DISCONNECT THE ELECTRICAL CONNECTORS AT WIPER MOTOR..THE WIPER ARMS HAS TO COME OFF.BUT GET A REPAIR MANUAL.IT WILL MAKE YOUR JOB EASY.
Windshield wiper system module / motor
Windshield washer fluid pump
Windshield washer fluid level switch
Instrument panel cluster (IPC)
ACC 15-amp fuse
WSW 30-amp fuse
