Does this happen even when its in charging?
Testimonial: "When is connected you will see the thunder bolt symbol.Nothing charges.I also have trouble flashing the Rom for my tablet.I use the same rom it came with and it installs everything successful.When i reboot to the Samsung logo it won't boot to get to the graphic user interface.I know it's bricked.Is the tablet in bad shape for example not good anymore.I am due for a new device."
SOURCE: Tablet doesn't turn on, it shows a battery with an triangle and this symbol!
When you have the charger plugged into the tablet and wall outlet does the triangle change to a lighting bolt if it doesn't change try a different changer either the charger or charging port or charging cable might be bad
SOURCE: How Do I Reset an Idolian Studio 10 Tablet that is looping on the Android logo?
The robot dude meant it was loading up the system settings to the next screen so you can wipe off corrupted data that prevents the tablet from completing startup.usually an incomplete update.So
as follows ... Hold power button to switch off tablet....then hold power button and volume up together for at least ten seconds.let the robot appear and do nothing until the menu option comes up to ask you to factory restore.you will lose all your apps and data.if the robot comes on and gets stuck make sure the tablet is fully charged and repeat the two button hold as this may take several attempts.sometimes Chinese technology is unpredictable.
I don't know much about them but I had the same problem with another tablet. Try keeping you finger pressed against the screen when you restart it for about 20 seconds max. It may work.
