SOURCE: Black mark on clothes after washed in Maytag top load washer.
Check and make sure the seal at the bottom of the washer is not wore out. Alot of times you will get grease from the bearins and drum assembly if this wears out.
SOURCE: White spots on color clothes
try using calgon tablets, they flush out washing machine for limescale, perhaps it will work for you
SOURCE: Whirlpool Calypso GVW9959KL1 ruins clothes
I can assure you this IS a common problem. I can't tell you how many customers I have had in the past that complained about their Calypso's leaving the same marks on their clothing. The problem occurs because of the suction on the clothes as the washer extracts water from them during the final nunator cycle. The nunator is the wash plate that the clothes get caught in. The manufacturer's cure for this problem was to come up with a modified control board that reduces the final nunator time and minimizes the suction action on your clothing. The replacement control board part number is 8571359. I have ordered and installed this board on a few Calypso's. I'm surprised that nobody advised you of this in the past. If you call Whirpool back and they deny this, I got this information from them. It may be worth your while to contact them again to see if there is a recall on this and if they would cover the cost of the repairs.
SOURCE: Whirlpool Duet Dryer is scorching clothes
there is a sensor in the exhaust line in the dryer, near the motor. this tells the heating element to shut off when it gets to a certain temp, either during reg cycle or if the exhaust gets clogged, it is meant as a safety measure, but it sounds like yours is bad so the heating element never shuts off. it is not an expensive part and easy to replace
SOURCE: Lint on dark clothes in my Whirlpool Cabrio washing maching
sorry there right ..your not using he or low suddsing detergent ,or your using to much..as the water pumps out of unit the sudds stick to side of tub than when rinse water comes in it washes back on your clothes...i can only give you tips and something to look for...look for water not drainning fast enough ,,cut down on detergent,,wash your dark clothes first..give your unit a bleach clean about a pint of bleach..keep me posted onthejob
