Microwave Ovens Logo
Charla Mcclinton Posted on Jan 11, 2020
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My sharp carousal microwave doesn't do anything. It has four blinking A's that's showing where the set timer is but I can't stop the blinking and wen I push numbers cook or even timer I can't get it to work. So what can I do. A friend of mind just gave it to me it came on by itself then went off.
jws1013
Level 3:
  • Master 1,713 Answers
  • Posted on Jan 11, 2020
jws1013
Master
Level 3:
Answers
1713
Questions
Helped
458135
Points
6786
You can try and unplug it for 5 minutes, push the on button to make sure it's completely discharged. Then plug it in. If it does the same thing, it's toast. Getting it repaired will cost about the same as a new one on sale.
5 Related Answers
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Aug 21, 2008
SOURCE: sharps microwave
This is usually caused by either a bad door switch, a loose door switch mount, or occasionally a problem on the control panel.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can probably find exploded views and order parts by entering your model number (R-520JKF) here at the Sears parts site.
The best place to order Sharp parts is Tritronics.
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Jan 29, 2009
SOURCE: Sharp R-1870 stops at 59 seconds
Wow. I just read something ridiculous!
Well, never mind that, here's your solution:
This is a common problem in one of the damper-related components, most likely the switch, but it may also be the motor or the damper door.
The damper is a door inside that opens or closes depending on cooking mode. If the controller senses that the door is not in the right position, it will shut down the cook cycle.
Sharp models stop after 59 seconds.
See the attached sample photo for a typical damper assembly.
We have the applicable service manuals for these models and have uploaded it to our site here and here to help you. You will need the free Adobe Reader to view or print it.
If a switch is all you need, we offer a universal type for only $5 postpaid which you can order here.
Anonymous
  • 180 Answers
  • Posted on May 30, 2009
SOURCE: sharp R-1871 microwave/convection oven. Microwave will not work
This may be due to the microwave section not working. Check the high voltage diode if it is ok, replace the Magneton.
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Aug 31, 2009
SOURCE: The number display on my Sharp R-515EK 1200 watts microwave oven
We regularly repair these control / display units for customers nationwide by mail for $39.95 postpaid in about a week or so with a one-year guarantee.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
[email protected]
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Anonymous
  • Posted on Oct 20, 2009
SOURCE: Sharp Carousel Model R-1440 won't shut off
Take it immediately to a local Microwave repair shop...looks like one of the circuits may have gone...otherwise switch off from mains
Where is the reset button at on my sharp carousal model r-209 ek
Microwaves don't have a reset button. Try unplugging for 5 minutes
2answers
Sharp microwave 8888 is flashing and I cannot remove
see this steps and fix it. God bless you
Reset the clock. Press "Clock" and the correct time, using the number pads. Press "AM/PM" if applicable, and press "Start" or "Clock" to confirm.
  • 2 Press "Timer On/Off" to reset the timer if nothing on the touch pad will operate. Use the number pads to select a new timed amount, if desired, and press "Timer On/Off" to start. Press again to cancel.
  • 3 Press and hold "Clear/Off" for three seconds if the timer will not function or is blinking when you touch the pads. This will release the "Child Lock" feature. Make a new touch pad selection.
  • 4 Disconnect power to the microwave if following Steps 1 through 3 does not resolve the blinking timer. Wait a few minutes, and then restore power to reset the microwave.
  • However if the problem persist the display board
    main control board is faulty
    My sharp 1214 won't heat anything. power is good - timer and clock are fine. stopped working in the middle of heating something. we use often. carousel is not rotating anymore either.
    Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
    Basic Microwave Oven Troubleshooting Tips
    heatman101
    When set the timer, etc and then shut the door the
    yes it is switch problem there must be three or four switches replace all together
    Sharp Carousel Model R-1440 won't stop running
    It may be a sticking door switch (upper or lower, not the middle one) or the mount of one of those switches may be loose, broken or out of alignment.
    See these files:
    http://www.microwavedisplay.com/safety.txt
    http://www.microwavedisplay.com/disassembly.txt
    http://www.microwavedisplay.com/doorsw.txt
    At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
    Then you can get to the switches.
    Or it may be a sticking relay on the control board. We regularly repair these control units for customers nationwide by mail for $39.95 postpaid in about a week or so with a one-year guarantee.
    If during this unwanted operation the oven lamp, internal cooling fan, and stirrer are all stuck on, but the turntable is not on moving and the oven is not actually cooking, then I would suspect relay RY1 on the control board is stuck.
    That's what I suspect in your case.
    100helpful
    5answers
    How to set the clock on my sharp carousel microwave
    Touch STOP/CLEAR pad.
    Touch TIMER/CLOCK pad.
    Enter the correct time of day by touching the numbers above in sequence.
    (for example: for 12:30, touch 1 2 3 0)
    Touch TIMER/CLOCK pad again.
    1helpful
    2answers
    No numbered touch pad for use setting clock
    I think on this one you press the CLOCK/TIMER pad, then enter the desired time using the 10 MINUTES, 1 MINUTE, AND 15 SECONDS pads then press CLOCK/TIMER again.
    If that doesn;t work, press STOP / CLEAR then try the above again.
    Let us know if it does not work.
    Noisy
    That's probably a shorted high voltage diode or a bad magnetron.
    Sometimes a failed magnetron sounds like someone gurgling into an empty coffee cup.
    We have the service manual for this model and have uploaded it to our site here to help you.
    Here are some links you or someone you know can use for test help, but read their safety warnings first:
    http://www.gallawa.com/microtech/diode.html
    http://www.gallawa.com/microtech/mag_test.html
    http://www.gallawa.com/microtech/xformer.html
    Top Sharp Microwave Ovens Experts
    ZJ Limited
    ZJ Limited
    Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
