Without a remote control, you can't. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check this site too. http://remotesearch.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops; and by Online shopping.
SOURCE: My remote control does not work. Where can I buy a new one?
An original remote for that unit is $19.95 plus shipping... Click on this link: http://remotes.com/?OVRAW=Replacement%20Remote%20Control&OVKEY=replacement%20remote%20control&OVMTC=standard&OVADID=4084295511&OVKWID=10268551011
and follow instructions..
Have a good day!
Bill
Hello, I had the same problem and after spending a few hours reading and trying things, I found a solution. Its very simple. Power on your unit (manually) and then on your remote control push and hold at the same time"enter" and the number "1" while pointing directly to your unit and this should solve the problem. Good luck.
SOURCE: jsi js4110
The only operations available on the JSI JS4110 without a remote are play, pause, stop, and eject. Since this DVD player "remembers" position of the movie, a different DVD would have to be inserted and played to start that movie over from the beginning. As for fast-forward, this is only available with the remote.
SOURCE: I own this dvd player, but do not know what the code number is
Go to www.remotes.com They have the original remote for this unit. As far as there being a code for it, every universal remote manufacturer has their own codes for their remotes. There is no set code for the unit itself. I hope this helps. Thanks for using fixya.
