Have LG Tech. Supp. walk u threw it, or while booting up press and hold power button and volume button simultaneously, you will come to a list of options, highlight factory reset and follow instructions. If this is a stolen or you found this phone, you might want to return it. Even after factory reset you will need, email, full name etc. when reregistering it...hope this helps...
SOURCE: Unlock my Sprint LG Lotus Phone if i forgot my lock password
As long as you know your security code you can retreive your lock code. On the Lotus dial ##3282# scroll down to Advanced, choose View, then scroll down to option 5 which should be the Lock Code and select it. You will need to enter your security code here which typically is 6 zeros.
SOURCE: my verizon droid i forgot pattern to unlock phone
Try to do a firmware restore, that'll wipe your data but the code will be gone too. Droid Repair.
SOURCE: i hav a lg gt540 then i put a pattern to lock my
hold volume up with home button and search button and it will do factory reset but take any memory cards out first it works because it happened to my phone
[email protected]
