DW60CHX1"
SOURCE: How to reset the flood switch on a fisher & paykel
Hi - unfortunately my good friend it cannot be reset as one would like quite easily anyhow... water has found its way to the base of the drwaers and have activated the flooding switch - one could pull it apart to dry it - tip the water out from the base but if the leaks not repaired you will have the same problem later and will be on-going. 5 Fault Codes Fault Code LED Display Fault Possible Causes F1 ----# The flood switch has been activated. A leak has occurred in the base of the dishwasher. Cause The fill valve has failed open. The flood switch is faulty. Excessive water has been added to a wash sub cycle, indicating leaking seal or siphoning. hope this is useful tp you - let me know if you require further asspstance...
SOURCE: HOw do you reset the
Hi
Thanks for using FixYa. When the flood switch has been activated you’ll need to reset it by powering off the
breaker or by unplugging the unit from the power socket and mains for more than
five minutes. Please check that there is no blockage in the drain hose and it
is not raised higher otherwise the water will run back to the dishwasher. Also
perform the following procedure---
Please do accept the solution if the issue is resolved or
post a comment for further assistance.
Thanks
Rylee
SOURCE: Error code 136 Fisher & Pykel washing macine
Hi just read your posting.Now Error code 136 means you have a motor stall fault.This means the motor controller cannot start the motor turning.Has your machine been noisy on spin?The things that cause this fault are,seized or faulty bearings, wiring to the motor faulty,faulty motor,faulty rotor position sensor, or faulty motor controller.Do you have or can borrow an electrical test meter ?If the answer is yes I can guide you throe the testing of the components to track this fault done.Please reply with additional information about the spin cycle and if you can get a meter and I will help you further.
SOURCE: Fisher-Paykel DD603 DishDrawer shows F1
Fisher-Paykel DD603 DishDrawer shows F1 fault code. The Flood Switch has been activated. I need instructions on how to re-set the flood switch. I have two drawers that are possitioned one above the other and the are both giving the error of the activated flood switch. Any advice or instruction is greatly appreciated.
