M
Morris Mohave Posted on Jan 09, 2020
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a error code E000002-0006 on my Canon IMAGE RUNNER ADVANCE C2020. How do I fix the problem?
Lenin Hudiel
Level 3:
Master:
  • Canon Master 934 Answers
  • Posted on Jan 15, 2020
Lenin Hudiel
Canon Master
Level 3:
Master:
Answers
934
Questions
0
Helped
508400
Points
7817
You need to clear that error from service mode first if problem persist replace the fixing unit
5 Related Answers
Anonymous
  • 67 Answers
  • Posted on Aug 19, 2008
SOURCE: Canon Image runner C 3200 printer gives error code E000677-0080
your quickbooks file is in the wrong format example tiff or pdf let your it know they can change it to the correct file format
color_50
color_50
  • 22 Answers
  • Posted on Mar 14, 2009
SOURCE: ROM Error for Canon Image Runner 2010F
When the ROM Error message is displayed on the control panel, this will indicate an issue with the Flash DIMM on the Image Processor PCB.
re-flash the system software for that specific model. If system software does not resolve the error, replace the DIMM Assembly. When replacing the DIMM, you may be required to flash the system software to it's latest version.
iR 2010F FG6-9454-000, Dimm assembly.
As a temporary work around, power on the iR while holding down the STOP key. This may boot the iR to a ready state and copies can be made.
57 varieties
Karl Wright
  • 1653 Answers
  • Posted on Oct 13, 2009
SOURCE: canon image runner error code E000000-0000
Note that clearing the error may not necessarily fix the fault.
Press the * with a circle around it then press 2 and 8 at the same time.
Then press * again.
Press copier touch button / function / clear / error /ok button then switch off.
Switch the machine back on.
The error code indicates that the machine doesn't sense the temperature of the fuser getting hotter. Usually this calls for the fixing film unit to be replaced because the thermistor has gone bad.
Anonymous
  • 622 Answers
  • Posted on Dec 21, 2009
SOURCE: Canon image runner 4570 in error code E000100-0001
Ok here is how to reset the error if that doesn't work... you really need to call a tech... you are going to need some serious work done on your copier... ok... here are the instructions
press additional functions
press code error
press copier
press function
press clear
press error
press ok
press reset
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Anonymous
  • Posted on Jul 30, 2010
SOURCE: Canon Image Runner 3300. Ii has error code
canon image runner 3300 has error code e000007-0000
Canon imageRUNNER ADVANCE C250i. I have error code E00074:000
Question edited for clarity.
Question moved from Washing Machines category!
It's not good news
Canon IRC 2030 E000074-0000
Copytechnet https://www.copytechnet.com > ... > Canon
Feb 8, 2012 - E074 is an Error in the Primary Transfer Disengagement Control. Check SW1 ( Primary Transfer Disengagement Switch) for Displacement. **Knowledge ...
CQ Error E000074 Canon c2030i - Copytechnet
Aug 29, 2019
Error Code IR Adv C2030i - E021-0120 and E074-0000
Dec 5, 2018
iR C2020 error E074-0000 - Copytechnet
Jun 17, 2020
canon image class advance c2025h e000074-0000 error
Sep 25, 2017
More results from www.copytechnet.com
Canon iR Advance C250i - Error Code
Printcopy.info https://printcopy.info > code=E074-0000
Code: E074-0000 · Description: Primary Transfer Roller disengagement control error. Signal was not detected although the ITB Pressure Release Switch was turned ...
Canon error code E000732-888
Hi, that error indicates there a internal comunication error between electronic boards, i suggest to get technical support.
Canon image runner 2020-2050 drivers
the little button with a guys head (Additional Functions) then 2&8 at the same time then add. functions again.
129helpful
5answers
Error code e000007 canon 2420
MY CANON IR 2420 WITH ERROR 000007-0000 HOW CAN ISOLVE THIS PROBLEM
1helpful
My canon color image runner c2050 is giving me a code E070-0001 and need to know what to do about it.
The error means that there is a problem with the transfer belt unit. You may need to replaces the transfer belt unit. You may need a service person to resolve your issue.
Code de panne E000584-0003 for canon image runner
Please check the main thermistor TH1 has poor contact or open circuit.,the thermal switch is opened.In this case the fixing heater has opened and the SSR is faulty.
For the reset : COPIER-FUNCTION-CLEAR-ERR.
2answers
Error code e000007-0000 for a canon image runner 22006
You have a problem with the fixing film. It is not a case that you have to reset the machine and carry on. Replace faulty parts in fixing and then clear the code. Most probably you have a damaged fixing film.
old marine
old marine
ZJ Limited
ZJ Limited
