Hi Sandro-
I found this youtube video.
https://www.youtube.com/watch?v=pzVxAStmJpk
I also found this youtube video.
https://www.youtube.com/watch?v=pViT2PI24wY
Hope these help.
There should be an open end at the back of the washer, where the house initially was fixed.
SOURCE: leak onto floor passenger side from neck of ac drain through firewall
It's not your heater core. If your heater core is out it would leak antifreeze. My wife's 97 Grand Cherokee had the same problem. It is condensation from your AC coming leaking through a round hole in the AC unit at the firewall. Pull the carpet back and dry out underneath it, there will be a lot of water and we had to leave the carpet pulled back with a fan blowing on it all weekend to dry out. I fixed this about 8 years ago so if I remember correctly, the was a plastic part of the AC at the firewall that had a hole in it that the water was coming out of, I could see leaves and debris in the hole so I know it was part of the drain system. I cleaned out what debris I could and used a cone shaped peice of rubber and twisted it in to plug the hole and tapped over the plug to ensure that it wouldn't back out with vibrations, etc. After you dry everything off start the engine and turn the AC on max, you'll be able to see the where the water is leaking from after the AC gets cold. Hope this helps, it drove us nuts for a year before we figured it out and the wet carpet smell wasn't pleasant.
SOURCE: GE tFX26KR side by side leaks water onto floor
I read this on-line and it worked for me - - pour HOT bleach water down the drain once you get the ice out. I had this problem for ages and would periodically clear the ice out of the bottom of the freezer but since the bleach water went down that hole it has been clear for months. Of course I discovered my s/s had been recalled for a water problem.
The GE recalls are a joke anyway - a credit toward buying another GE product. Nope, I am replacing my GE's one at a time with a different vendor.
SOURCE: Whirlpool GD25DF auto defrost drain problem
There is a drain hole in the back of the freezer on the bottom. Get back there with some hot water. Most of the time it is just lime build up. Unless you know what feel back there. Another way is to move the freezer out and from the back side you can see the drain line. It just pulls right off
SOURCE: Whirlpool Cabrio Washer- When draining, water leaks out of hole
probably rubber hose from tub to pump broke, access from back or bottom, (cabrios are open bottom) pump in rear. there is a recent bulletin about tub ring not channeling water from dispenser completely into tub
SOURCE: water leaking onto the floor from freezer drain...
Your evaporator coils frost up in normal use
and every eight hours or so the entire unit shuts down and the defrost heater
comes on to melt the frost. This cycle last about 20 minutes. The melted frost
drips into a drain pan and through a drain tube to the drain tray under the
freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end
because it drains too slow because it's stopped up at the lower end in the
evaporator pan under the unit at the floor. It can get dust and mold in it.
Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing
it out with hot water and clorox may help.
Make sure it drains quick enough to prevent
refreezing. .
