Hello, Keith -
I suggest you contact Fisher and Paykel Customer Care and ask your question directly. I have no idea the country where your washer was manufactured. Therefore, following are the links for country of manufacture:
USA: https://www.fisherpaykel.com/us/ Choose "Help & Support"
Canada: https://www.fisherpaykel.com/ca/ Choose "Help & Support"
New Zealand: https://www.fisherpaykel.com/nz.html Choose "Support"
Australia: https://www.fisherpaykel.com/au.html Choose "Support"
Fixya receives questions from people worldwide. I am answering from the USA.
Best wishes.
SOURCE: Fisher and Paykel Washer leaking water
call fisher paykel they will take care of you chances are the diverter valve is bad they have been having problems with them and make sure your repair people are fisher paykel certified VERY IMPORTANT
SOURCE: Fisher and Paykel Smart Dribe 608
not familliar with that exact model number ( we dont have that over here in the US) we have simalair f&p gwl10- gwl11) that problem sounds as if either the pump is bad and overheating before pumping all the water or a diverter valve is not fully closing allowing water to remain in tub.
SOURCE: Received error message fault 37 on my wonderful
Check the drain line for kinks or obstructions. Check the pump. Remove the hoses from the pump and use a flashlight to look into the suction port. Look for anything clogging the pump (like the occasional stray sock) and check the pump impeller for damage. Look for any broken/missing blades and make sure the impeller spins freely. If any blades are broken/missing or if you cannot get the impeller to spin freely, the pump is defective. Hopefully it's just a clogged drain line or pump. Sorry for your trouble and I hope this helped. Best wishes.
SOURCE: what is error code 136 on a fisher & paykel IW...
136 fault is 'motor stall'...Quite often this is a broken wire to the motor. However it could also be a Motor fault, or Rotary Position Sensor problem. Water damage can cause this fault as well. After a visual check for broken wires or water damage, and if your machine is in good condition, you should consider a tech....Good luck...Nomess
