Washing Machines Logo
Woody Uknow Posted on Jan 07, 2020
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Lg front load washer turns on shows sensing load but hums but never moves to wash cycle
ChinthakaJ
Level 3:
  • Master 943 Answers
  • Posted on Jan 07, 2020
ChinthakaJ
Master
Level 3:
Answers
943
Questions
Helped
301285
Points
2783
Time to take it to a repairman
5 Related Answers
Anonymous
  • 125 Answers
  • Posted on Jan 06, 2008
SOURCE: frigidaire front load washer problems
most likely something is stuck in the pump. it could also be that you are not using high effiency detergent.
Anonymous
  • 489 Answers
  • Posted on Jul 23, 2008
SOURCE: LG Front Load Washer Problem
The washer is not leveled correctly.  You will need to adjust the front feet to level the machine.  Run a load of clothes in the washer.  When it gets to the spin mode, check the level of the machine by pushing the front left corner and the front right corner.  If the noise quiets down on either corner of the machine, adjust the legs on that side.
Anonymous
  • 5911 Answers
  • Posted on Sep 02, 2008
SOURCE: kenmore elite HE4T front load washing machine standing water
This problem can be caused by either a leaking water inlet valve, or a condition known as "siphoning". Since you just recently moved, I would make sure you don't have a siphoning problem, first. The following link explains how:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
Although siphoning normally refers to a constant drain problem where a washer has problems maintaining the proper water level, it can also lead to problems where the drain line will back up into the washer.
Now, if you follow the advice in the link and determine this is NOT caused by siphoning, I would suspect that you have a water inlet valve that is leaking. A tell-tale sign will be water trickling down the fill tube in the rubber door bellow. The water inlet valves have a diaphragm that is controlled by an electric solenoid. Sometimes the valve becomes clogged with sediment or deposits, causing the diaphragm not to close properly. If you live in an area that has hard water, or use well water, you may have hard water deposits or rust build up in the valve. You may be able to correct the problem by removing the valve and cleaning it with some distilled vinegar. You can remove the valve by following these steps:
1. Unplug the washer and turn off water supply at the taps.
2. Disconnect the water inlet hoses.
3. Remove washer top panel by removing the three screws that hold the panel in place in the rear of the washer. With the screws removed, the panel slides back, then off.
4. The inlet valve (this is what your water inlet hoses connect to) will be located in the left rear of the washer (facing from the front). Remove the dispenser hose(s) from the valve and the electric connections. Remember how the electrical connections are removed. They should be color coded. One is for HOT, one is for COLD.
5. Remove the mounting screws that hold the assembly in place.
Once you have the inlet valve removed, you can place it in some distilled vinegar and let it soak. Just don't submerge the electrical connections. If this does not correct your problem, replace the valve. Searspartsdirect.com and repairclinic.com are two notable web sites that I have frequently used. Just type in your complete model number to begin the parts search.
I hope you find this information helpful. Let me know if you require additional assistance.
Anonymous
  • Posted on May 18, 2009
SOURCE: "le" on the LG WM0532hw front load washer errror
try unpluging for 45 seconds than hold in the selector knob for 10 sec. & plug back in
Anonymous
  • 2605 Answers
  • Posted on Sep 05, 2010
SOURCE: My Frigidaire front load washer
Welcome to FixYa.
Based on what you've described,...you likely need a door lock/switch assembly. The closest I found to your model is actually CLTF2940ES0.
The door latch is likely the single most common fault (which prevent's any spin, and consequently drenching wet clothing at the end of the cycle) with the frigidaire/electrolux built washer's, aside from pump's being obstructed.
I think it fool's many people because the lock indicates it is energized on the panel, however the built in "monitor" switch inside the assembly fail's. I do see a lot of these particular machine's...unfortunately.
You should be able to purchase one at most local brick
LG washing machine fix unplug plug in works
Question makes no sense as written. Is this what you mean?
We have to unplug the washer and plug in everytime ...
JustAnswer https://www.justanswer.com > Appliance Repair
Dec 12, 2020 - Unplugging the washer will reset the issue one cycle at a time, but to fix the issue completely the main board will need to be replaced. This is ...
1 answer · Top answer: This is a very common way for front load LG washers to fail. The problem is that the main ...
WM3470HVA LG Washer won't turn on until I unplug for 10 ...
Appliance Blog https://www.applianceblog.com > ... > Washers > LG
Jan 8, 2017 - My LG Washer just started an issue where it won't turn on when pressing the power button. But if i unplug it for 10 seconds, then plug it ...
FIXED - WM3360HVCA LG Washer Won't Power On
Sep 30, 2019
WM3470HWA LG Front Load Steam Washer Won't Turn On
Aug 17, 2016
More results from www.applianceblog.com
It appears to be a VERY well known issue!
https://www.google.com/search?q=LG+washing+machine+fix+unplug+plug+in+works
LG front loader. Why is it stuck on load sensing?
Pull the mains plug for 5 minutes. That is the closest you can get to a reset. Some do it by holding the On button as you connect the mains power. Continue to hold for 10 seconds and release. Aha, I just found this, and I was right.
LG washer stuck on load sensing To reset this issue, the manufacturer advises to unplug the machine, press the Start-Pause button, and hold it in for 5 seconds before restoring power by plugging it into the outlet. Check for code clearance by completing a Run-Rinse cycle. Overloading specific gentle cycles can cause the error code to appears as well.
How to Reset an LG Washer ' Hunker
https://www.hunker.com > ... > Washer & Dryers
Search for: LG washer stuck on load sensing.
My front load LG Tromm doesn't spin but turns left and right when in first cycles.
CALLED LOAD SENSING UNIT IS TRYING TO BALANCE LOAD IS WASHER LEVEL.... TRY ADDING CLOTHES TO WASHER TO EVENLY COAT TUB FOR EVEN SPIN
Spin cycle appears to be broken. washer just hums
Humming can indicate a stalled motor...If a coin is jammed in the pump impeller it will often do what you describe...Check via pump filter access door...Good luck....Nomess
LG front load washer does not drain after cycle. Motor runs,drum moves forward and reverse but seems pump doesn't pump. Drain hose clear as well as filter area.
Check for 120 volts to the pump motor while in drain mode, if the pump does not run, or just hums, replace the pump motor. Some LG's have both a recirculating and drain motor on the pump casing, so be sure to replace the correct motor.
Wash cycle not filling with water
Does the washed show an error?
Check all hoses in back. Remove them from washer and ensure water is coming from lines (drain into bucket).
Unplug washer for several minutes, then try again.
1helpful
LG Sense Clean DD error code "FE" front loader washer/dryer combo
my lg senseclean wash mashine shows the sign Cl on the display and the door cannot be open what does it mean?
Front loading lg washer
if you have the spin sense option, try enbaling that on the washer
Lg washer 2277, spin cycle
The humming noise is probably the drain pump working to remove the water out of the tub.  It is normal.
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
