SOURCE: I have a sc532 error code on a Lanier 5228
Try to press these bottons one right after the other... The yellow "C" then the numbers 1 >0 >7 then press and hold the "Clear/Stop" botton till the display changes. Then turn the Main power switch OFF then back ON... I Believe the error code deals with the fixxing unit. If it clears, you may have a power problem in your outlet
SOURCE: Ricoh MP C2500 Error Code SC 561 what is this?
sc561 on an MP C2500 is a thermopile error. The thermopile may need to be replaced, but first make sure it is connected properly and hasn't been moved or loosened.
You'll need to go into service mode and execute SP 5810 in order to clear the sc561 code.
