Oscar Sebele Posted on Jan 07, 2020
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi got panasonic model SA-AK220,it turns on but with no sound,if i increase volume it increases well but no sound,what could be wrong,thanks in advance
Level 3:
  • Panasonic Master 6,688 Answers
  • Posted on Jan 07, 2020
Cindy  Wells
Panasonic Master
Level 3:
Answers
6688
Questions
0
Helped
3532959
Points
21745
What speakers do you have connected to the SA-AK220? This is the main unit of the SC-AK220. WIthout the SB-AK220 speakers or another set of speakers connected to the black and red connections for the Right and Left speakers on the back of the SA-AK220, you will not get any sound output.
I hope this helps. The manual for this mini-audio system is available from ManualsLib: https://www.manualslib.com/manual/117595/Panasonic-Sc-Ak220.html .
5 Related Answers
Anonymous
  • 377 Answers
  • Posted on Mar 01, 2008
SOURCE: Negative volume Panasonic SA-HE75
What the max volume?
Anonymous
  • 32 Answers
  • Posted on Nov 12, 2008
SOURCE: GN Netcom wireless headset volume adjustment
Transmit volume adjustment
Adjust the volume of transmitted sound according to personal preference.
To adjust the volume:
1. Make a telephone call and ask the person you are calling to assist
you.
2. Press the +/– buttons on the headset simultaneously for 2 seconds.
A beep will indicate when 2 seconds has passed.
3. Adjust the volume level by pressing the + or – button.
4. When the person you are speaking with fi nds the volume of your
voice appropriate, press the +/– buttons simultaneously for 2
seconds. This setting is now stored in the headset.
A Copy of the manual is avaliable at:
http://www.onedirect.es/files/GN%20Netcom-ES/GN%20Netcom%209120%20manual.pdf
You must have Adobe Reader to view it and the instructions are on page PDF page 3 or manual page 6. Adobe Reader is avaliable for download at:
http://www.adobe.com/products/acrobat/readstep2.html
Anonymous
  • 71 Answers
  • Posted on Jun 02, 2009
SOURCE: Sound through right speaker is not proper Creative Inspire M2600
This sounds like an electrical problem in the speaker circuitry - between the speaker(s) and the control knob.
shaun taylor
  • 1527 Answers
  • Posted on Apr 05, 2010
SOURCE: Technics SA-DV290 Amp. Sound cuts out as volume is increased
hello it sound like the output ic may be in trouble you may have just dry joint on the ic which just resolder it . or there could be a capacitor leaking or they may have swelled up in which you will have to replace. it's best to do some visual checks first i'e look for any burnt parts any capacitor with bulging tops
regards
shaun
Anonymous
  • 160 Answers
  • Posted on May 07, 2010
SOURCE: Dynex t. v. the volume control button increases
Make sure this is happening from two sources such as a dvd player and a gaming system as well. If it happens from two sources the speakers are more than likely not working or the sound board will need to be replaced. A cheap way of getting around a repair is by getting a surround sound and running a cablebox, dvd player, and/or your gaming system directly to the surround sound system using it for sound instead of the tv.
Hi, I have Panasonic model KX-TSC901CID phone. I want to increase the volume. How can I do it. Thanks
Try these:
-Try restarting your phone, The most classic way of troubleshooting devices
-Try cleaning the speaker if you see any dirt blocking the hole
-You can download speaker booster on googleplay e.g. volume booster, sound booster
2helpful
2answers
Got a Panasonic CD stereo system SA-AK410 When I turn it off after a few seconds it turns back on. Is this normal?
That's because you haven't set the clock on the system. I jumps to DEMO mode once you turn it off without the clock set. Clock can be set through your remote. Hope this helps. Cheers.
Panasonic sa ak220 wont turn on
The problem is in the audio output ic, it is loading the unit into shutdown. The only option is have the ic in the stereo replaced.
Sound is weak how to increase volume
Please check your all the audio and video connections. Also put the placing of AV Enhancer (button on remote control) in the ON position You can increase the volume by increasing the volume of the TV.
2helpful
How to increase ringer volume of panasonic kx-tc2100bx model cordless phone
Go to Menu > Ringer Setting >Ringer Volume > use Right or Left arrow to adjust the volume of the ringer
thank you
6helpful
Manual for Panasonic model KX-A143BXW
I have Panasonic model KX-A143BXW phone.
Humming through speakes when on auxillary
Most humming in North America is either 60Hz or a harmonic of 60Hz. The number one cause of humming is a poor common. On co-axial cables this is the outside connection where as the signal is the male post in the centre. Corrosion, oxidation, poor contact are all possible things to check.
2helpful
PANASONIC SA HE9 RECIEVER 5.1
If the sub has a volume control, turn it down then turn up the volume on the amp to the very high volume you mentioned. If it still has very low muffled sound, then we know the problem is about the amp.
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
