Question about Plumbing
How do you get the handle hole cover off of a rainfresh faucet?
3 Suggested Answers
Anonymous
SOURCE:
goofduck
Jeff Adkisson
  • 490 Answers
SOURCE: faucet handles fell off
there are supposed to be screws in the handle thru to the stem on the faucet that hold them on
Posted on Apr 21, 2009
dartagnonp
Dartagnon puissant
  • 15 Answers
SOURCE: The handle on the Ideal Standard single faucet in our kitchen fell out.
All sorts of things come to mind. Get on your computer and track the company and see if they offer replacement parts or an upgrade. Looks like you'll need to drill the hole and retap the threads. OR go down to a Michael's if you have one or any place that would sell wooden dowels. Find one that is a tad larger and whittle it to fit the hole. Use teak or something strong. It won't look stock but if you do it nicely you can stain the wood and make it look good, spray some clear on it to make it water-proof. You can also try running a tap through the threads to see if the threads can be repaired. Long shot but if you are on GREAT terms with the Powers, a small miracle would be nice ... but it CAN HAPPEN> I have run taps through some beaten threads and they have come back to life. The last option would be to have a machine shop make another steel dowel but thread it for the next size up and drill and tap the hole to match.
Posted on Dec 12, 2014
Which is the good single handle sink faucet?
Eyekepper is a good sink faucet. The sink faucets come with Matching Esutcheon Cover Plate Chrome and many other amazing facilities. The faucets provide both hot and cold water and it comes with a lifetime breakage warranty and 30 day money back guarantee.
Specifications
  • Color: 6009-Chrome, Chrome
  • Finish: 6009-Chrome
  • Mounting: Deck-mounted/ Single hole
  • Number of holes: 1
  • Handle/ Lever placement: Centerset
  • Number of handles: 1
  • Main Body Material: Zinc Alloy
  • Spout reach: 3.1 inch
  • Spout height: 5 inch
  • Overall heights: 6.3 inch
  • Water Mode: Waterfall
  • Water Feature: Mix Hot and Cold
  • Water Pressure: Minimum 0.5 bar, 1.0 bar recommended
Pros & Cons
Pros
  • Beautiful design
  • Inexpensive
  • Convenient
  • Easy to install and use
  • Fine quality
Cons
  • Noisy activities
Apr 02, 2018 | Plumbing
How to remove the screw under the plug button on the moen 7065
Easy! Simply turn the water off, pry the cover loose, raise the handle until the screw head is centered in the access hole, find the right size allen wrench and remove the screw, then the handle can be removed.
Jun 15, 2014 | Moen 7560C Extensa Kitchen Faucet
Dripping bath faucet circa 1985. Can't ID model but appears to have 2 screws holding front of casting to main body for disassembly . Faceplate is square in shape and black in color HELP!
  • 1 Close the hot and cold water valves in the cabinet beneath the sink to shut the water supply off to the bath faucet.
  • 2 Remove the bath faucet's handle to access the valve cartridge. The faucet handle is removed by first detaching the handle's insert cap using the tip of a screwdriver or utility knife to expose the handle screw. Remove the handle screw with a Phillips screwdriver, then pull the handle off the valve cartridge stem.
  • 3 Loosen and remove the cartridge valve nut with an adjustable wrench. Some faucet models retain the valve cartridge with a snap ring and are removed with snap ring pliers.
  • 4 Pull the old valve cartridge out of the bath faucet base, using pliers.
  • 5 Insert the new replacement valve cartridge into the faucet housing and replace the nut or snap ring removed in Step 3, using an adjustable wrench or snap ring pliers.
  • 6 Reinstall the faucet's handle onto the valve cartridge post, then secure the handle's screw, using a screwdriver.
  • 7 Replace the insert cap into the handle to cover the handle's screw hole.
  • 8 Turn on the hot and cold water valves beneath the sink to restore the water supply.
  • Jun 15, 2011 | Kohler Plumbing
    Our Kohler Fairfax kitchen faucet 12176 has a difficult spout swing from side to side that I thought would get easier over time. It is installed on granite and when I use hot water is very difficult to...
    was the base installed under the faucet..is there a single hole in granite...faucets usually come with a long base to cover the holes in sink..or with one round ring for granite installation..which the faucet should be mounted on..
    Nov 22, 2010 | Kohler Fairfax Single Control Lavatory...
    How do you separate the handle from the faucet. Americian standard Gold faucet.?
    On the underside of the handle, all the way back on the round part there will be a hile that is sometimes covers with an little cap that you need to pop off with a knife or a small screwdriver. In that hole is a set screw that you will need an allen wrench to loosen. An allen wrench is a six sided peice of metal that will fit into the six sided whole in the set screw. Different handles will take different sizes, so you will have to find the right size to fit snuggly into the set screw hole.
    Loosen the set screw and then you should be able to lift the handle up and off of the stem.
    Hope that this helps you to solve your problem.
    Thanks for using Fixya!
    Heatman101
    Nov 21, 2009 | American Standard "Ceramix" Single Handle...
    Need instruction for installation pull out faucet
    firs you have to remove the handle
    remove lastic cap on top or no cap look for a erasure size cap or ruber tab on the side
    take a flashlight and determine if you need an allen head screw or phillps
    remove the screw( be sure to cover your drains so nos small parts get in bottom
    remove the handle
    depending on the type of faucet you may have to unscrew a large nut holding the cartridge in place
    whatever remove anything holding the cartridge down (some require a cartridege remover)
    remove, take to store match up new and replace
    by all means turn water of under sinnk good luck
    TIP anytime you have to put a wrench on chrome protect chrome with a wash cloth
    Jan 08, 2009 | Dmm KWC K.24.41.61.000C28 Gastro Deck...
    Trying to get the handle off a single handle moen kitchen faucet
    Hi adelinette,
    Pry the cover off the top of the faucet with a little screwdriver. Under the cover you will find an allen head screw. Sometimes a little upward pressure with a screwdriver will help. Unscrew it and start disassemblying. Pay attention to part location as you take the faucet apart. you will be replacing a stem and not a washer when you get into it.
    Good Luck and please rate this response, Phil
    Jan 03, 2009 | Moen 7437 Chateau Single Hole Kitchen...
    Problem taking the top cover off the Rohl R77V3SPN one handle faucet
    With a small flat blade screwdriver, carefully remove the red and white plastic button on the front of the faucet. Turn off the water supply. Then, raise the handle like you're turning on the water and move the handle slowly left and right until you can see an Allen screw through the hole where the button was. With the correct size Allen driver, remove the screw and the handle will come off the faucet.
    Nov 06, 2008 | Rohl R77V3SPN Country Pull-Out Bar Faucet...
    Plumbing Logo
    32 people viewed this question
    Top Plumbing Experts
    Tom Chichester
    Gil Shultz
    Are you a Plumbing Expert? Answer questions, earn points and help others
