Sc 672 Controller-to-operation panel communication error at startup
Possible Causes
? Controller stalled
? Controller board installed incorrectly
? Controller board defective
? Operation panel connector loose or defective
? The controller is not completely shutdown when you turn the main
switch off.
Check the setting of SP5875-001. If the setting is set to "1 (OFF)", change it
to "0 (ON)".
SOURCE: ricoh 1045 error code sc 672, 961
Controller to operation panel comucation error at start up.Check the controller stall,controller board installed correctly operation panel connectors.Enter im the service menu ,press the SP mode,open the front door,turn off the copier,unplugged the machine.Wait 10 seconds,plugged on the machine,close the front door,turn ON the copier and make a copy.
SOURCE: Problem with the Ricoh mp c2800 Ricoh error code
If the model ia a MPC 2800 it a controller board issue maybe the operation panel. -carl
SOURCE: Ricoh sc 672 error on new machine
Try checking or changing the thermistors!
The metal contact spring on the thermistor broken causing all sorts of 'unrelated errors including 'Please Wait' sc 670 and sc 402...
