You can do that by pushing the enter button for few seconds until the display changes mode. In case of an error message is displayed, even if the displays already have been reset with entering(LED Light is still blinking).
Status Message and information about the cause and removal
www.keb.de => Documentation => Operating Instructions => Other => Service informations =>Error and status messages.doc.
You can see on the manual.
If you have plan to have a diesel generator set, please refer to www.dieselgeneratortech.com
SOURCE: F5 keb inverter problem
i have a prblem in the F5 keb combivert it's show Error
E.OC & E.puci & E.Puch could you please advice us with the proper solution
thanks
SOURCE: F5 KEB inverter nop problem
If using bus communications (Can, ProFi, Mod, ext), there may be a communications command (Software signal) that is not being provided. Hardware and software enable signal required to obtain LS.
Possible that the terminal on the control card is bad due to miss connection or signals outside of the rated value.
SOURCE: RESET PASSWORD
Push the function and enter buttons at the same time until the display changes modes
Forward CONtinues
System is at the commanded speed in the forward direction.
