Question about Building Materials
Chamberlain the led light blinks 7 times when trying to reprogram
Anonymous
SOURCE:
Therinnaiguy
Chandler Ede
  • 1420 Answers
SOURCE: the led light blinks 3 times then pauses then
Pressure switch error code, Check the air filter for blockage, check the vent pipes for blockage or water, make sure the condensate drains are working and that there is no water in the hose(s) that go to the pressure switch(s).
Posted on Jan 06, 2010
Ivan
  • 308 Answers
SOURCE: no picture,no sound, standby led blinks 7 times - over and over
It's an error code. Call a Sony repair shop for an estimate.
Posted on Mar 22, 2010
Don Maggard
  • 3197 Answers
SOURCE: I have a Chamberlain Garage Master 1/3 HP, Model
Your logic board is bad.
Posted on Dec 13, 2010
Daniel S
Daniel Scott
  • 4323 Answers
SOURCE: I have a whirlpool quite porter the led light
Hi
If clean light is blinking 7 times then it may be an issue with heater circuit, door switch or wash pump. If yes then please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset.
If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back for further assistance.
Posted on Feb 14, 2011
William keena
  • 34 Answers
SOURCE: LED LIGHT BLINKS 7 TIMES FAST OVER & OVER
Call philips to talk you through the reset option or arrange a replacement it may have a higher warrenty
Posted on Dec 21, 2011
Replaced battery and now remote doesn't work, do I have to reset the remote.
Yes. If the battery runs out, or you loose power to the opener for a period of time, you will have to reprogram the remote.
On the back of the opener motor you will find a 'learn button'. It may be under the plastic light cover, or in plain sight. It will either be green, orange, purple, or red. When you press the button an LED light just above the learn button will come on. Hold the remote near the opener and hold down the remote button. You should see the lights blink on and off a few times.
Try the remote. If this doesn't work try it again.
Good Luck!
Also, don't forget to check the balance of your garage door. This and other garage door maintenance tips can be found at www.spokanegaragerepair.com/tips_tricks.htm
Mar 07, 2011 | Chamberlain Liftmaster 81lm Remote...
I have a liftmaster garage door keypad which when the code is entered now just blinks and doesn't raise the garage door
Change the battery in the keypad and reprogram
Program:
1- find learn button on back of motor
2. push the learn button ( LED stays on for 30 seconds)
3. during the 30 seconds enter a 4 digit code on the keypad , then press the enter button for 5 seconds
NOTE: do not pass throught your safety sensors when programming
Apr 07, 2010 | liftmaster Chamberlain Garage Door Opener...
Chamberlain remote has stopped working, new
WHEN YOU CHANGE THE BATTERY NO NEED TO REPROGRAM THE REMOTE.
THE FLASHING LIGHT TELLS YOU IT IS SENDING A SIGNAL THAT IS BEING RECIEVED IT IS JUST NOT THE CORRECT CODE TO OPEN THE DOOR.
REPROGRAMING THE REMOTE SHOULD SOLVE THE PROBLEM
HOPE THIS HELPS
Sep 28, 2009 | Chamberlain Powerdrive PD422D 1/2 HP...
Remote does not open garage door
It sounds like the wall button has the lock feature engauged.
Is there a small green LED flashing inside the wall button?
Push and hold the lock button for about two seconds and the LED should stop flashing. This will unlock the garage door opener and your remotes should start working. You may have to reprogram your remotes and homelink again since you triedprograming in the lock mode.
Good luck.
Jan 20, 2009 | Chamberlain 950CB Remote Control
Building Materials Logo
Top Building Materials Experts
Tom Chichester
Lawrence Oravetz
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
