Question about Schlage Locks & Locksmithing
I have a Schlage FE595 Keypad Lever lock that needs the battery changed, but I cannot remove the cover after removing the screws.
Cannot get the face plate to separate after removing both screws.
  • 6,073 Answers
There are two Philips head screws that hold the inside cover in place; a manual screwdriver is better than a power one. The screws are positioned close to the 12 and 6 o'clock (12-hour clock) positions around the lever handle. Thus the top screw is below the manual lock; there may be a cover partially hiding the fastener. The manual for the FE595 is available from Schlage here: https://www.schlage.com/content/dam/sch-us/documents/pdf/installation-manuals/23780042.pdf . Make sure to look at the picture for your lock since the manual covers at least three models of keypad locks. A better picture may be in the installation guide here: https://images.homedepot-static.com/catalog/pdfimages/cf/cfae64fe-e7be-4146-bc26-4803ec302d5e.pdf .
Try carefully running a utility knife or other thin blade between the inside cover and the rest of the lock housing on the door. You may have some dirt sealing the two sections of plastic together.
I hope this helps.
Posted on Jan 04, 2020
Testimonial: "Cindy - thank you very much, but I had removed those screws but was limited in my character count on my question so couldn't say that. With the screws out, I can't get it to separate... Thanks again, Mike"
Anonymous
SOURCE:
Anonymous
SOURCE: how to change the battery on my BE365-CAM-716 Schlage Keypad Deadbolt
Problem fixed by having my wife look it up on the Schlage website. The deadbolt has a flash memory so your combinations and codes will not be lost when the batteries are changed.
Posted on Sep 30, 2008
Coaltowner
  • 963 Answers
SOURCE: Instructions needed for changing the
How can I program my electronic keypad lock when the instructions with the programming code have been lost?The back plate of the keypad side of the lock on the exterior of the door has a sticker which includes the serial number, six digit programming code and two pre-programmed four digit user codes. The lock must be disassembled to a point the exterior of the lock can be pulled away from the door and the information on the sticker made note of.
This link will give you instructions for various models of Schlage locks:
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
Posted on Mar 06, 2011
Coaltowner
  • 963 Answers
SOURCE: I lost the manual for
Go to this page for downloadable instructions and videos:
A note about PDF files: If you cannot view a given file, you need to first install Adobe Reader. You can get the free download here:
http://get.adobe.com/reader/
Posted on Nov 08, 2011
Coaltowner
  • 963 Answers
SOURCE: Lost instructions on how to
This link will take you to the page you need, to get started:
Then scroll down to this heading on that page:
Electronic Security-Keypad Entry Flex-Lock...
There's a wealth of info under that heading. You will be able to see a PDF file of the original print instructions, as well as a video of how to install the lock. This is useful because there should be a sticker to be found on the backside of the keypad, with the code number ( the programming code) that you need to reprogram the lock. This installation video (fourth item down) will be useful to allow you to disassemble it and view the sticker. This is also a great time to change the 9-volt battery! A battery should last about three years under normal usage.
The ninth item under that same header is a video which walks you through how to reprogram the keypad to your new code, using that program code that you found on the backside of the keypad.
A note about the PDF files: If you cannot view a given file, you need to first install Adobe reader. You can get the free download from here:
Good luck--and please provide feedback if this helps!
Posted on Nov 10, 2011
Coaltowner
  • 963 Answers
SOURCE: Schlage FE595 keypad replacement part
Your best bet is to contact Schlage directly. You can call during Midwest business hours (Mon.-Sat 7-7) at this number:
Warranty & Technical Information 1-888-805-9837.
For further information for the FE595 (installation & programming manuals and videos), go to this page:
http://consumer.schlage.com/Service-Support/Pages/InstructionsandManuals.aspx
The manuals are PDF files. If you cannot open them for viewing, you need to first download & install Adobe Reader, which you can get here:
Posted on Feb 22, 2012
Schlage keyless lock lost 6 digit code and no sticker inside either
You will need to take the keypad look off of your
door and record the 6 digit programming code and the two factory
default PIN codes. You then need to perform the factory reset to
erase any codes and restore the lock back to the factory defaults.
This procedure is outlined, as well as the programming of the device, in the attached instructions.
http://www.factorylocks.com/PDFs/Programming%20Instructions.pdf
Regards,
Leslie
Factorylocks.com
877-345-6257 (877-34-LOCKS)
Jan 13, 2013 | Schlage FE595 Plymouth Electronic Keypad...
The switch that unlocks my schlage FE595 door lock from the inside needs changed and I can't find a replacement.
Schlage's warranty policy covers the electronics for 1 year to the original purchaser. Last week I answered another question about buying the keypad assembly for a Schlage lock. Here's his experience:
"I had commented on their site about no spare parts being available and one of their reps contacted me and says they are going to replace the lock for me. This is a very generous gesture on their part and if it comes thru, will be a great deal for me. However, the problem still remains that there are no parts available for the other people that have this same problem. The locks have a lifetime warranty on the finish and mechanism but the electronics only have a 1 year guarantee...."
I suggest that you contact Schlage, but you will probably find that you can't buy the switch you need. Plead your case, ask to have it elevated, make a negative comment on their website like the other gent did.
Here's the contact information:
Go to Schlage.com Click on :"For your Home", then "Service & Support", and under that "Contact Us"
Feb 26, 2012 | Schlage FE595-CAM-ACC FE595CAM620ACC...
Feb 21, 2012 | Schlage Electronic Lock FE595 Plymouth or...
I need to change the batteries and reset the pass code in (2) keyless locks ("Locknetics On Board"). The owner's manuals were never given, and the key (Schlage) override was never used.(No...
This number is the programming code referenced in the information for changing the entry code.
This link will take you to the page that you need to get started:
Electronic Security-Keypad Entry Flex-lock FE595/Keypad Entry Auto-Lock FE575 Documents
There's a wealth of info under that heading. You will be able to see a PDF file of the original print instructions, as well as a video of how to install the lock. This installation video (third item down) will be useful to allow you to disassemble it and view the sticker. This is also a great time to change the 9-volt battery! Batteries should be replace about every three years.
The eighth item under that same header is a video which walks you through how to reprogram the keypad to your new code, using that programming code that you found on the backside of the keypad.
Jul 06, 2011 | Schlage FE595VCAM716ACC Camelot Keypad...
Fe 575 how do I change the battery? and code?
Electronic Security-Keypad Entry....
There's a wealth of info under that heading. You will be able to see a PDF file of the original print instructions, as well as a video of how to install the lock. This is useful because there should be a sticker to be found on the backside of the keypad, with the code number that you need to reprogram the lock. This installation video will be useful to allow you to disassemble it and view the sticker.
Jun 28, 2011 | Schlage Electronic Lock FE595 Plymouth or...
When I punch in my code for my Schlage FE595, the code is accepted and the schlage key blinks, however, it does not allow for the unlocking or for me to open the door. Also, when I set my door from the...
You did not indicate whether this is a new installation that you are having difficulty with,but I'm going to assume that it is.
I'm going to direct you to a web page that has a wealth of information for the Schlage locks:
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx#1
This page has links to the PDF file of the installation instructions, which you should already have in your possession:
http://consumer.schlage.com/Project%20Documents/P515-859.pdf
Also, there are two videos that may be helpful in troubleshooting your problem:
Installing your FE 595 Keypad Entry Lock video:
And, Programming Your FE 595 Keypad Entry Lock:
The reason that I think it's a good idea to review these two videos is that again, assuming this is a new installation, is that you may spot a mistake in the initial installation process.
Was the "Thumbturn" in the proper position when the inside plate was installed? (Shown at the 5 minute mark of the installation video)
Also to be found on the Service Support page link is a link to Schlage's Service & Support
which will allow you to contact Schlage if the problem remains unresolved after reviewing your installation.
I hope this helped. Good luck!
May 20, 2011 | Schlage FE595-PLY-FLA FE595PLY620FLA...
I need to change the combo for my fe595 and dont know how. the serial number is 715739 andthe user codes are: A 6152 and B 1514. How do I reprogram the combination?
Feb 06, 2011 | Schlage Electronic Lock FE595 Plymouth or...
Schlage FE 595 - - Just quit. Changed battery, codes, etc. Get green blinking light - hear click - doesn't engage. Disassembled - spring good, slides work, placement of round headed pin could be the...
Electronic Security.....
Nov 15, 2010 | Schlage FE595-CAM-ACC FE595-CAM-716-ACC...
I lost the manual for Schlage FE595-CAM-ACC and I do not know How to change the code for Schlage FE595-CAM-ACC . Are there any downloadable instructions for it online?
Oct 15, 2010 | Schlage FE595-CAM-ACC FE595-CAM-716-ACC...
I am looking for the downloadable instructions for the FE595 V CAM 716 ACC. I need to change my code and I can not find my instructions.
Sep 20, 2010 | Schlage FE595-CAM-ACC FE595-CAM-716-ACC...
Locks & Locksmithing Logo
Top Schlage Locks & Locksmithing Experts
JOHN LAPIER
Mike
Are you a Schlage Lock and Locksmithing Expert? Answer questions, earn points and help others
