SOURCE: proselect pace master treadmill incline does not work
Dear Sir:
1) You must test the Main motor board, RUN the software calibration for easy diagnose and troubleshooting.
2) The elevation motor has a Potentiomente adjust. 3) The gear from elevation motor can be LUBE. However RUN the s. calibration.
3) Another machine has relais for down and up, you must clean the relais contact, if the board has relais.
sincerely. God bless you
SOURCE: I have a pace master treadmill ..with an error
Dear Sir:
This error indicate :1) deck belt very worn! you need lube and exchange.
2) IF the system use SCR , can be shorte.
3) Filter capacitor shorte in motor.
3) Drive motor coil shorted or open demanded more current.
In short RUN The software calibration for easy diagnose and troubleshooting. May be you must need the assistance from some Service Tech.
Sincerely. God bless you.
