Question about Electronics - Others
Can I Transfer pictures from aPNY OPtima 2GB card time a 6th generation IPad?
5 Suggested Answers
Anonymous
SOURCE:
ikkenom
  • 10406 Answers
SOURCE: How to install PNY OPTIMA 2GB DDR2 667 MHz memory card in lap top
Turn the computer off.
Remove the battery.
Unplug the AC adapter.
Turn the computer bottom-up.
Look for a few screws that secure a small panel.
Unscrew those screws, and remove the panel.
If you've selected the right panel, you should see your current RAM.
On the LEFT and RIGHT edges, there are small "fingers" that are holding the RAM.
Gently pull those fingers away from the RAM, and it should pop-up slightly, and you should be able to remove the RAM.
Notice that the "notch" in the middle of the RAM is slightly off-centre.
Insert the new RAM into the socket, and gently press down, until those two fingers "click" to grab the new RAM.
Depending on your "old" RAM, you may have:
* one "occupied" RAM slot (1GB), and one "empty" RAM slot;
* two "occupied" RAM slots (512MB/stick).
So, you may have to remove one RAM stick, to expose an "empty" RAM-slot "hidden" under the RAM.
Or, the "empty" RAM-slot may be visible without removing the RAM.
Or, you may have to remove one of the 512MB RAM-sticks, in order to free-up a slot for the "new" RAM.
Replace the cover-panel, and screw it in.
Reconnect the battery.
Reconnect the power-supply.
Start the computer.
Click Start
Point at My Computer
Right-mouse click on My Computer
Choose Properties
It should display your CPU-speed and the "new" amount of installed RAM.
Posted on Dec 10, 2009
Ty Price
  • 11967 Answers
SOURCE: How do I transfer pictures
Go into the menu and find "copy"...this gives you the option to copy the internal memory to a memory card.
Posted on Oct 10, 2010
Jason7FixYa
  • 54 Answers
SOURCE: I am trying to get
If you look real close at the card, you will find a micro switch, used to protect the contents. Flip the switch and try again.
Posted on Dec 19, 2010
tobibus2000
Oluwatobi Busari
  • 506 Answers
SOURCE: I formatted my PNY OPTIMA
I'm afraid you may not be able to get the files again.once you format your memory card, the whole file you got on it gets wiped off.you will need to get new files and pictures on it.
Posted on Sep 20, 2011
How can I transfer music from a flash drive like leaf bridge to my iPad Air and then have that music stored in iCloud?
You can attach some flash drives to Apple's $29 iPad Camera Connection Kit. (If you have an iPad with a Lightning connector you'll additionally need Apple's $29 Lightning to USB Camera Adapter.) Let me underscore some. Some flash drives require more power than the iPad can provide and won't work.
For the second question, here's also a guide to help you back up iPad music to iCloud.
  1. Connect your iPad to a Wi-Fi network.
  2. In iOS 8 or later, tap Settings > iCloud > Backup. ...
  3. Make sure that iCloud Backup is turned on.
  4. Tap Back Up Now. ...
  5. Make sure the backup finished by tapping Settings > iCloud > Storage > Manage Storage, and then select your iPad.
If you have a new computer, you can also backup iPad music onto it.
http://www.leawo.org/tutorial/how-to-sync-iphone-to-new-computer.html
Apr 11, 2016 | Apple iPad Air
How do I transfer pics to my iPad from my canon A480
Save the pics from your camera memory card to your computer, then transfer them to your iPad via iTunes or iTransfer. Here's a guide for your reference.
How to Transfer Pictures from Computer to iPad Air 2
Feb 14, 2015 | Canon Cameras
How to transfer pictureshow to transfer picture from my dell laptop to my I pad air?
The easy way is transferring pictures from laptop to SD Card, then insert the SD card to I pad and you can show and transfer the picture from it.
Aug 14, 2014 | Computers & Internet
I bought a PNY Optima SD 2GB card, loaded it in my Lumix camera and took a number of very important pictures (of my engagement) which is let me take and I can see in the review mode of my camera. I then...
for safety I would take the SD card to a local Photoshop and see if they could print the Pictures for you. If they can, then they should be able to copy the data from one card to a new one. Try then to upload the pictures from the new card to your computer. If this does not work then you have a defective cad reader on your computer. You could buy an inexpensive external card reader which plugs in into your USB port.Aprox $25 at Walmart.
Oct 04, 2010 | PNY Optima Pro 2GB Secure Digital Memory...
I have a PNY optima sd 2gb memory card and it tells me on my samsung camera card error. What does this mean?
My Sanyo camera says my sd card it full when it absolutely is not. Ive even tried uploading pictures to my computer and it tells me there is an issue. It just suddenly did this one day and I think I've lost about 150 photos from Easter and other things that I can't get back and worse I can't take any pictures with my camera now.
Mar 09, 2010 | PNY Optima Pro 2GB Secure Digital Memory...
I had almost 300 very important pictures on my PNY optima SD 2gb card. All but 27 are gone literally out of no where! I use a Canon Rebel camera. Is there any way to retrieve these pictures? There was no...
Do you have any other inf on flash drive which is readable? If so lost files may be hidden and you may be able to retieve using appropriate hard disc recovery softaware set to read a USB stick
Oct 03, 2009 | PNY Optima 2GB USB 2.0 Flash Drive - Dark...
Electronics - Others Logo
32 people viewed this question
Top Electronics - Others Experts
Marvin
Marvin
Tom Chichester
Are you an Electronics - Other Expert? Answer questions, earn points and help others
