It sounds like there's a problem with the charger. The wire on the charger is rather delicate. So is the port on your tablet where the wire plugs in. There may be a break inside the wire. If you dropped your tablet while the wire was plugged in and it hit the floor on the charger plug, the charger plug could have damaged the charging port in the tablet or the wire itself could be damaged.
Find someone else who has the same tablet and ask to switch chargers to see if either of them still work on the other tablet. If your friend's charger starts charging your tablet without a problem, then the problem is a a broken wire in your charger. If neither charger will charge your tablet but both chargers charge your friends tablet without a problem, then the problem is with the charging port on your tablet.
first of all these tablets take a long time to charge. second check the cable were you plug into tablet to make sure the holding clips are working and take hold. My first choice and most inexpensive is to buy a new charger. Also check plug in port for damage. look at warranty to see if it is still covered and get replaced. />
If the cable has a micro USB connector (most android tablets do), then the connector is likely the problem. With the cable plugged in, there should be a light to indicate charging. It would usually be orange until charged, when it turns green. If you don't see the light atall, the connection is bad. Try wiggling it to see if that helps. If it does, then you will need to make sure the phone is charging somewhere so that it is not subject to being moved at all, which might cause the connection to become loose. The phone will charge faster if it is off.
Make sure the keyboard is plugged all the way into the tablet. Since you didn't say what kind of tablet/ keyboard combo it is (wireless, wired, bluetooth) I'll just assume it's the kind you plug in. So do that, then power down the tablet and restart it, all with the keyboard FULLY plugged in. You prolly just don't have it plugged in all the way. Pretty common problem for people who have no idea what they are doing.
Try to charge your tablet pc with your laptop or desktop pc.
if it will show the charging then your charger may be out of order.
if it will not charge with your laptop or desktop then your tablet's charging circuit not working.
Is your battery removable? Try removing the battery and then plugging in the tablet. If the tablet runs on only the AC power, then your battery is shot.
