To restore your printer's default settings to troubleshoot an error, you may have to reset HP printer network settings. Thus, you should know how to reset HP printer network settings. Firstly, locate and press the Power button and hold it. Now, press the Network button for two times and then tap on the Cancel button five times. After that, release the Power button, and your printer network settings will be reset. https://connectmyprinter.com/how-can-i-reset-my-hp-printer/
asked 3 time, now do this is BIOS
power off. hold button for 10seconds, intel reset magic
then power on
hammer esc at HP spash
and use F1 or F2 as it prompts you to info page bios
got lines now>?
this is for a 99 but 2000 should be the same. There might be a red Reset button. Press for about 5 seconds, and release. The Reset button is in the fuse/breaker box under the hood,
A factory reset erases all user-installed settings, programs, and data, and restores your HP iPAQ to factory settings. CAUTION All user-installed settings, programs, and data are erased from memory with a factory reset. To perform a factory reset and return your HP iPAQ to factory settings:
Press and hold the OK and Rotate Screen buttons.
While holding these buttons, use the stylus to lightly press the Reset button on the HP iPAQ until the device restarts.
When the HP iPAQ restarts, release all of the buttons, and then remove the stylus from the Reset button.
The HP iPAQ will now restart and power on.
If you have done the above and still no go. Then your main drive has probably failed.
Multiply the subtotal by 123. If this multiplication
results in a number greater than 99,999,999 (this should never happen), use the
special password of 44122333.
Since the only valid choices are 1-4 for each digit, follow
these rules:
If the digit=0 (zero), make the digit=1
If the digit=9, then make digit=1
If the digit>4, subtract 4 from the digit
If the digit does not meet any of the above, leave the
digit unchanged. If the result is less than 8 digits, add leading 1s to make it
eight digits in length. NOTE: As an example, 2000
02/07 2:30 is displayed (February 7, 2000 at 2:30). Plugging in the numbers:
(2 * 1001) + (7 * 101) + 2 + 2000 = 4711
4711 * 123 = 59453
Convert all digits to be between 1 and 4 = 131413
Add the leading 1s to make it eight digits long -
11131413
Enter this special code to the front panel.
Press OK. The
screen will confirm that the password has been
reset.
1. Press and hold the Quick Launch and Rotate Screen buttons. 2. While holding these buttons, use the stylus to lightly press the Reset button on the HP iPAQ until the device restarts. 3. When the HP iPAQ restarts, release all of the buttons, and then remove the stylus from the Reset button. The HP iPAQ restarts and powers on
It doesn't mention a password. I also have an HP Ipaq and don't need a password to hard reset. Good luck. If this helps you plz rate this. Thank you kindly.
Try a Reset.... Performing a Clean Reset will help A clean reset clears all user-installed settings, programs, and data, and restores your HP iPAQ to factory settings. To perform a clean reset and return your HP iPAQ to factory settings: 1.Press and hold the Answer/Send, Power, and End Call buttons. 2.While holding these buttons, use the stylus to lightly press the Reset button on the bottom of the HP iPAQ until the device restarts. 3.When the HP iPAQ restarts, release all of the buttons, and then remove the stylus from the Reset button. The HP iPAQ restarts and powers on. Thanks
Try This:-
1. Press and hold the Quick Launch and Rotate Screen buttons. 2. While holding these buttons, use the stylus to lightly press the Reset button on the HP iPAQ until the device restarts. 3. When the HP iPAQ restarts, release all of the buttons, and then remove the stylus from the Reset button. The HP iPAQ restarts and powers on.
Mike @ compurepair.
