That error occurring due to high voltage in your residing area. We believe the IFB Washing Machine protects your machine by tripping. We have a Gelco GA 400 Voltage Stabilizer to buck or Lower your upcoming Voltage from GEB. It has capacity of 12 amp and 15 to 20 Voltage up /down capacity. We are sure this Gelco GA 400 model will solve your problem. You can Call on: 9722658052 or 9427347880 Thank You
A variety of stabilizers are available.
Curious about where it made?
https://www.youtube.com/watch?v=-bbFLyJFzqU
If input voltage is too high then AC H1 error will come. So wait for sometime to stabilize the voltage then washing machine will start automatically. If not then call to your electrician to solve the power fluctuations
Laundry load is unbalanced. If laundry load is small. It can lead to an unbalanced condition. Add 1-2 similar items to help balance the load and rearrange load to allow proper spinning.
SOURCE: washing machine
This may be a little late, but it may assist someone else. On my Kleenmaid top loader I found the agitator has clips at the bottom of agitator that clip over a drive hub at the bottom of the "tub" . All you have to do is gently prise it up using your fingers between the bottom of the agitator and the bottom of the tub.
Paul
SOURCE: IFB washing machine dryer not working
can you supply the enr?
first port of call is the overheat stat, switch off mains remove lid and in the middle top of the unit there should be a metal chamber that houses the dryer heater, somewhere there, you will see a stat that should have a reset button on it, if you press the button and it makes a definate click, it was tripped. There are some reasons for this, you may be stopping the dryer early and not letting it do the last 10mins which is a system cool down, the fan is not operating or slow, the unit is not draining properly (check pump filter) or you are trying to dry more than 2.5kg (half a load).
Good luck.
SOURCE: How to fix error f
Hi and weclome to FixYa, I am Kelly
An F54 code is a motor over current fault. This is caused by a severe load on the motor or a bad motor bearing.
To remove the error press Pause/Cancel twice. Before removing the error.. try and find out why the motor is hard to turn. There may be an article of clothing stuck at the top of the inner tub or between the inner and outer tub. (
If the unit has previously had an ld code (long Drain) this can also cause high motor currents if the water level switch allows the washer to spin when not completely empty. Usually an ld code is associated with something stuck in the pump / pump inlet or possibly a bad pump.
Thanks for choosing FixYa,
Kelly
SOURCE: i have ifb elenaa washing machine. my problem is that water can't enter or drain from machine .help
make sure the water is turned on at the faucet handle behind the washer.
