Question about LG Televison & Video
I need dish remote code for lg 75um6970pub tv
Anonymous
SOURCE:
Bob Citizen
  • 520 Answers
SOURCE: Dish Network universal remote
Here are the codes for Orion tv's for Dish Network remotes.
Orion: 694, 720, 729, 220, 221, 623, 695, 227, 754, 721.
Posted on Nov 14, 2008
Jim Franks
  • 374 Answers
SOURCE: My dish network remote isnt working with my LG tv
Not all TVs are supported by our remotes. You can do a power scan to see if you can find one that works or you can get the newest remote type that supports a large array of TVs. The new rmote is a model 21 which will work in IR and UHF mode. To perform a power scan do the following: Press and hold the upper left TV button on the remote until all lights on top light up and release.Now press the small red TV button and release - the upper tv button should be lit solid. Now press the arrow up key slowly until set turns off. Once it does presss the arrow down key once and then the arrow up key and the TV should power on. Now press the pound sign and the rrecord button. Now press the upper SAT button and release . You should be able to control the set now. Thanks for using Fix Ya.
Posted on Apr 13, 2009
Jim Franks
  • 374 Answers
SOURCE: need sharp tv codes
The codes for a Sharp are 526, 585, 591, 605, 606, 607, 608, 628, 629. Thanks for using Fix Ya.
Posted on Aug 15, 2009
Anonymous
SOURCE: I need a dish network remote control code for an ESA television.
try some of the akai tv codes in dish network directory, firstone worked for me, hope it works for you
chris
Posted on Feb 13, 2010
kimberlyesco
Dish
  • 184 Answers
    Verified Fixya Pro
    SOURCE: Need remote code for LG
    Hi there my name is Kimberly Escobar with DISH Network Customer Support. I understand you need the codes to program a DISH Network remote model 3.0 to an LG T.V. Some of the codes we have are 678, 506, 520,123, 000, 512, and 213. To integrate the code into the remote you would need to press and hold the clear T.V button at the top until all the other top buttons light up in red, then once you see them light up you would need to enter one of your codes followed by the pound key (#) for example if you choose code 678 it would be 678#. After you press pound the T.V button will flash in red 3 times after that try the remote and make sure it functions with your T.V. I hope this is helpful to you. You can also view this link http://www.dishnetwork.com/SupportSection/power-scan-instructions which contains information on how to program your remote to your T.V using a different procedure. If you have any additional questions or concerns please feel free to contact us directly at 1800-333-DISH thank you.
    Posted on Feb 01, 2011
    I need the code number for my new lg tv so i can make my control turn my tv on and off
    The remote codes we have listed for LG are as follows; 627, 766, 124, 520, 666, 773, 521, 505, 653
    To program the remote, hold down the cear "tv" button until all four mode buttons are lit.
    Next, Press the three digit code follwed by pound (#).
    Daniel Busa
    DISH Network
    Customer Service
    Apr 01, 2011 | DISH Network IR Remote Control
    How to program dish remote to control volume of LG tv
    jacques_bull
    I have provided a link on how to program your DISH remote to you LG TV. This link contains all our receivers. Choose the type receiver you have and select that link. The instructions on how to program your remote will display in a PDF document. I hope this helps.
    Program the remote, step 5:
    http://www.dishnetwork.com/SupportSection/remote-setup
    These are the common codes for the LG TV: 678, 156, 520, 512
    Ray Calo
    DISH Network
    Feb 19, 2011 | DISH Network IR Remote Control
    HAD REMOTE2 set to turn on/off LG TV. trying to reprogram and it wont take code nor scan to find. Sat works tv does not.
    dmmcgregor
    I'm sorry you are having problems reprogramming your TV 2 remote to your LG TV. Have you replaced your batteries? If so, I have provided a link on how to reprogram the remote and how to perform a power scan. I will also give you several codes that should work with the LG TV. This is the link with the instructions for programming the remote to your TV. It begins with step 6.
    If you have any other questions or problems, please respond to this site.
    Ray Calo DISH Network
    Jan 22, 2011 | DISH Network IR Remote Control
    I have bought a brand new lg tv from sams. I suscribe to the dish network. I can program the dish remote control mto turn the lg tv on, but the remote will not adjust the volume ! The dish remote is new...
    Hello there!!!!! If your remote is giving you troubles, you can try a power scan, which scans through each code for the tv until you reach the correct one. Just follow the link provided below, and begin the scan. Remember when you are done programming your remote, press the SAT button on the top left of the remote. Hope this helps!!!
    Becki Barned
    DISH Network Customer Service
    Dec 08, 2010 | LG 50PG20 50 in. Plasma HDTV
    Need remote code for LG 32lcd350 TV for dish 3.0 remote
    Sep 05, 2010 | DISH Network IR Remote Control
    Remote control programming in tv codes LG
    Hi this is Kimberly Escobar with DISH Network; to program your remote control to your LG television you can most definitely try integrating a code to it. Some of the codes we have for the LG brand would be 678, 506, 520, 156, 766, and 627. To program the remote you would press and hold the T.V button at the top of the remote until all the other buttons light up in red once you see that all the other buttons light up you will enter one of the codes you have followed by the pound key (#), you will then see the T.V button light up 3 times. After this procedure you can try using your remote with your T.V and verify it works. There is also another way of programming the remote to your T.V in case the codes don't work that procedure is called Power Scan. On this procedure we actually search for the code instead of just integrating it to the remote. here is this link http://www.dishnetwork.com/SupportSection/power-scan-instructions here you will find the procedure and more information about your remote. Hope this helps if you have any questions or concerns please feel free to contact us directly at 1800-333-DISH.
    Aug 03, 2010 | DISH Network IR Remote Control
    3 digit codes for 42" lg lcd tv for dish network
    We would be happy to help you with getting your DISH Networkremote to control your LG TV. We're going to start by pressing and holding the TVbutton located on the top of your remote until all mode button back lights comeon, and then release. Use the number buttons to enter the codes for your LG TV; here are some of the codes we currently have: 627, 505, 520, 506, and 581, then press the pound (#) button. To check if the code works try severaldifferent functions on the remote to make sure it will properly operate yourTV. Remember that some codes may not be compatible with your equipment. If thisis the case, try the other codes listed for your LG TV until youfind one that is compatible with it.
    We hope this helps and thank you for being a valued DISH Network customer!
    Phillip Chang
    DISH Network Customer Service Representative
    Feb 13, 2010 | LG 42LH30 42 in. LCD TV
    I need codes for a LG TV for Dish Netwrok remote
    lqaztec4
    I have provided a link with instructions on how to program your DISH remote to your LG TV. Just click on the link, select your receiver model, and then follow the directions. At the bottom of the page is a link with the TV codes. Again, select your receiver model and look for your TV model. I hope this helps.
    Ray Calo
    DISH Network
    Jun 27, 2009 | DISH Network IR Remote Control
    Remote Code
    We would be happy to help you with getting your DISH Networkremote to control your LG REAR PRO. Pressand hold the TV button located on the top of your remote until all mode buttonback lights come on, then release. Use the number buttons to enter thecodes for your LG TV; here some of the codes we currently have: 506, 520, 627, 581, 766, and 512.Press the pound (#) button. To check that the code works try several differentfunctions on the remote to make sure it will properly operate the TV. Keep inmind that some codes may not be compatible with your equipment. If this is thecase, please try the other codes listed for that device until you find one thatis compatible with your equipment.
    Phillip Chang
    May 30, 2009 | DISH Network ViP 211 DTV Receiver
    Need code to program dish remote
    the dish network code is in the cd that comes with the TV.
    Jan 18, 2009 | LG 42LG70 42 in. LCD HDTV
    Televison & Video Logo
    Ekse
    RONALD CARTER JR
