SOURCE: Amana Radarange Microwave/Convection over the stove
what is the model number of your radarange? it should be found inside the microwave on the rim.
SOURCE: Instruction manual for 1986 Amana Radarange microwave
I think it will use a standard generic probe for the Accu-Temp. Sorry I couldn't help. Take care.
SOURCE: Need to change bulb inside Amana radarange RR1220
There is an access / cover panel on the back of the oven.
It's shown in the exploded view here.
Please unplug the oven from the wall first.
Then use a 1/4" nut driver or socket to remove the screw in the end of the lamp cover.
The bulb is behind the cover, and should be readily available at grocery stores, home improvement centers, hardware stores and big box stores like Wal-Mart.
SOURCE: help setting clock on amana radarange microwave made in 1987
press Reset, then enter in the time of day (e.g. 0807 for 8:07 am or pm doesn't matter), then press Clock button twice. hope this helps.
SOURCE: steam gets in the door and how can we clean and prevent?
This is usually due to incomplete venting or impaired air flow.
Assuming your hood vent exhaust fan is running properly, be sure your grease filter is clean (or if you use a charcoal type, it must be replaced when dirty) and be sure the exhaust ductwork and outside flapper are all clear.
I recommend that you always run the hood vent exhaust fan whenever you are cooking on the stovetop, too.
You can find links to helpful exploded
view diagrams and part ordering help
here. You can get new filters there, too.
I recommend that you bookmark that
link to your favorites.
We're happy
of our answer.
