HardReset.info: If you have forgotten the security password (also known as a lock code) for your NOKIA C5-00 and there is no other way to perform the hard reset you should try uploading a new firmware by performing the flash operation on your cell phone. That way you will restore the default password but also lose all data on your device and bring all settings to the factory state.
HardReset.info:To accomplish successfully the whole operation you should perform the followings steps:
SOURCE: Phone lock needs unlocking - samsung g600
switch the phone on without a sim card,
type in *2767*2878# WAIT for it to reset,
once it boots up itself, the phone code is now gone,
if the phone is asking for a SIM LOCK password
then send it to someone who has the equipment to unlock it
SOURCE: Forgotten My Phone Lock Code
Please Goto a Sony-Ericsson Service Centre They will Sove It ...............................
SOURCE: S.E. W850i Phone Locked
Yes, Its 100% tested and working solution.
Follow these steps;
If you want to unlock the security code follow this;
You are done, enter 0000 or the Noted one (In the 3rd last step)
If I was Helpful, Kindly Do Rate!
Regards,
Waqar.
Testimonial: "This was Great. Thanks. Worked Like a charm. Any Idiot could do it. THanks soo much."
You can format your Nokia N70 device by typing: * + 3 + call + Power on. Before the device is reset, you need to provide the lock code. The default lock code is 12345.
If it is not working try this code:
You can format your device by typing *#7370# in standby mode. Before the device is reset, you need to provide the lock code. The default lock code is 12345.
Some Nokia phone can be reset via this menu option
Press menu button or enter Menu > Settings > Phone > Phone management > Factory settings > Delete data and restore > YES
