Dishwashers Logo
Steve Dwenger Posted on Jan 01, 2020
Samsung DMT 400 dishwasher. There is power at the dishwasher but power button does nothing
Andrew c
Level 1:
Problem Solver:
  • Contributor 9 Answers
  • Posted on Jan 12, 2020
Andrew c
Contributor
Level 1:
Problem Solver:
Answers
9
Questions
0
Helped
4954
Points
22
Samsungs have a power "filter board" in the base of the dw.This is different from the main board. This is most likely the culprit and can be checked with a voltmeter. You should have 120 volts coming out of the filter board if it is working. If not, that is your problem.thanks
1 Related Answer
Anonymous
  • 41 Answers
  • Posted on May 05, 2011
SOURCE: how to connect the water
http://www.youtube.com/watch?v=dKdP7Fp5XEI
http://www.thisoldhouse.com/toh/how-to/step/0,,20076102_20174094,00.html
Samsung DMT series dishwasher starts to fill then quick light flashes
A Samsung Dishwasher flashing the Quick light indicates a Water Supply Error (Not Enough Water) has been detected by the internal electronic diagnostics.
https://appliancerepairinfo.com/samsung-dishwasher-quick-light-flashing/
I have a low level water error code on a Samsung dmt 300 rfb model dishwasher normal and heavy and quick lights .are flashing after it runs for a couple minutes
There are a couple or reasons that this might be happening. One is the heating element in the bottom ALSO heats the water to a higher temp. If it is burned out, that can cause the issue. Another is the fill valves may have screens on them that are full of debris.
The last would be the control panel and it is not cheap.
2answers
Samsung DMT - 400 delicate light blinking
please follow this steps and fix it. God bless you
Heating Element
If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Heating Element Assembly
If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Check Fault Codes
If the display lights are flashing and there is an error code in the display window, check the wiring diagram and tech sheet in the dishwasher that will provide information on the fault.
Drain Pump
If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective You'll need to replace it. Drain pumps are not repairable.
Touchpad and Control Panel
If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad
If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Jul 09, 2013 • Dishwashers
1helpful
2answers
I know this is old, but I had the same thing happen to me (exactly as mentioned) and what worked was to replace the control panel. Fortunately, I had a spare I bought several years ago when I thought that was the problem to another issue which was solved without replacing the control panel. Instead of returning it, I kept it and it came in handy since it's either too pricey now or difficult to find. But that did it for me. I did everything to this dishwasher and already had a replacement picked out because nothing was working. Before doing getting a new one, I thought why if the issue was not the dishwasher. So I checked the hose and made sure no quinks or obstructions. I then checked for particles on the motor. Before that, I cleaned out the filters and replaced the check valve. I confirmed the motor was pushing out the water at a good pressure. Everything was fine. What turned out to be the problem was not anything to do with the drain but the control panel. I usually don't write comments, but I hope this helps someone.
By the way, wrap your control panel chip with plastic and put cotton inside to absorb moisture. The plastic will prevent the condensation from ruining the panel chip. I know this because I replaced my first control panel due to condensation/moisture/steam - whatever you call it coming out of the dishwasher. After doing this, it lasted until the blinking delicate light which isn't due to moisture. I will never again buy a Samsung dishwasher or any of their kitchen appliances.
Samsung dishwasher dmt 300rfb wont drain and is humming
Hello Randy Lowe,
There is an EXPECTED INITIAL failure period
on new equipment...!!
Use your warranty...
Brand new = Take it back & get a GOOD ONE.
Carnac the Magnificent
Adjusting legs on DMT 300 dishwasher
on the bottom of the dishwasher, under the door there is like another panel accross the bottom, pull this off, and you should see the legs for the dishwasher. they might be small one that u need to turn to adjust the height. hope this helps. good luck
Top Samsung Dishwashers Experts
vince
Daniel Blask
Daniel Blask
Are you a Samsung Dishwasher Expert? Answer questions, earn points and help others
