Question about LG Televison & Video
I have a brand new 55" LG webos tv. I hit power button on tv remote to shut it off and it keeps coming back on. How do I shut it off so it stays off?
    Top Expert:
  • LG Master
  • 66,470 Answers
Call the place you bought it for warranty service
Posted on Dec 31, 2019
Anonymous
SOURCE:
Anonymous
  • 3130 Answers
SOURCE: TV auto shut off-power indicator light blinking-won't turn back on
You could have gotten an electrical surge that put your set into a shutdown condition and unplugging the set and letting the Microprocessor reset will fix this problem if it dosent blow out the main power regulator as you still or might I say have a regulator IC problem. IF THIS PROBLEM HAPPENS AGAIN MORE THEN A FEW TIMES WITHIN A SMALL TIME FRAME I WOULD HAVE THE SET LOOKED AT BEFORE THE REGULAOR BLOWS SOMETHING OUT!!!!
Posted on May 14, 2006
Ajkill
Anand Kumar
  • 2035 Answers
You can also try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works..
If you are having some problems with your Sony Television, then this post is for you. Generally speaking, when there is trouble with your Sony Television set -- it indicates the issue in either the diagnostic mode, or even more commonly by flashing a series of LED blinks or flashes on the front of your television. Each set or frequency of the blinks indicates a very specific problem with the television itself. In some cases, you may be able to repair the television set yourself -- or in the worst case you may need to order parts, call a local repair shop to the have a repairman sent out, or even purchase a new television set.
First off, here are the list of codes and what they generally mean on my set (which applies to many recent model Sony Television sets. Sony has provided a "self-diagnosis function" with your TV, that in the case of abnormalities or problems the LED or red blinking light on the Timer/Standby indicator flashes a number of times to indicate the issue. Here are the values of the various blinks.
* 0 times, Diagnosis: Power does not turn on. Possible causes include: Power cord is not plugged in, Fuse is burned out (F6001) (G board). Symptoms of the problem: Power does not come on, No power is supplied to the unit, AC power supply is faulty.
* 2 times, Diagnosis: B overcurrent (OCP). Possible causes: H. OUT (Q8024) is shorted. (D board), +B PWM (Q8035, 8038) is shorted. (D board) Symptoms of the problem: Power does not come on, Load on power line is shorted.
* 3 times, Diagnosis: +B overvoltage (OVP). Possible causes: IC501 is faulty (G board), IC5002 is faulty (G board). Symptoms of the problem: TV has entered standby mode.
* 4 times, Diagnosis: Vertical deflection stopped. Possible causes: +- 15V is not supplied. (D board), IC8003 is faulty. (A board) Symptoms of the problem: TV has entered standby state after horizontal raster, Vertical deflection pulse is stopped, Power line is shorted or power supply is stopped.
* 5 times, Diagnosis: White balance failure (Not balanced) Possible causes: Video out (IC7101, 7201, 7301) is faulty (CR, CG, CB board), CRT drive (IC309) is faulty (A board), G2 is improperly adjusted. Symptoms of the problem: No raster is generated, CRT cathode current detection reference pulse output is small.
* 6 times, Diagnosis: LOW B OCP/OVP (Overcurrent/over voltage). Possible causes: +5 line is overloaded. (A, B boards), +5 line is shorted. (A, B boards). Symptoms of the problem: No picture.
* 7 times, Diagnosis: Horizontal deflection stopped. Possible cause: Q8035, 8038 is shorted. (D board)
* 8 times, Diagnosis: High voltage error. Possible cause: T8005 is faulty. (D board)
* 9 times, Diagnosis: Audio error. Possible causes: +- 19V line is shorted. (A, B boards), IC708 is faulty. (A board), PS701 or PS702 is opened. (A board). Symptoms of the problem: No sound
If you would like to attempt a DIY, you will need a service manual to guide you. You can find one here:
http://servicemanuals.vstore.ca/
However, be aware that there are voltages inside your TV set that can kill, even if unplugged.
Posted on Jul 08, 2008
Anonymous
  • 57 Answers
SOURCE: tape won't eject,tv keeps shutting off
sounds like your tape is jammed try turning the tv on and ejecting the tape while using something to try to lift the tape up and out good luck.....
Posted on Jan 11, 2009
Anonymous
  • 12 Answers
SOURCE: 42" LG 42LC2D HDTV Will not turn on
Hi, sounds like a power supply problem, most likely needs capacitors replaced, costs about £5 to do it yourself, and a fortune in the repair shop, easy enough if your handy or know someone who is,its worth a try,it'll be going in the bin anyway, cam
Posted on Jul 14, 2009
Anonymous
SOURCE: 55" TV keeps shutting off automatically
Green light flashes 5 and then red light flashes 6
Posted on Sep 28, 2009
Screen flickers on and off
If all your other HDMI inputs are out, then I recommend replacing the MAIN PCB
try the following web site: https://www.encompassparts.com/model/ZEN55UB9500UA/_/_/LG/55UB9500UA/55_INCH_UHD_4K_SMART_3D_LED_TV_W_WEBOS
page 4 lists a part number for the MAIN PCB,
HOWEVER, PLEASE MAKE SURE YOU USE YOUR COMPLETE MODEL NUMBER TO ASSURE THE CORRECT PART.
Apr 06, 2015 | LG 55UB9500 55" 4K Ultra HD TV with 2160p,...
Tv shuts off, when turned back on, the green light keeps blinking and tv wont come back on. if you leave off for a few min. the tv will come back on. then the tv will shut off again after a few min.
One of two things...first hold power button while you hold the up button on your remote, this will reset your tv to manufacturer's settings....you could have sleep timer on.....if this does not work, you have to replace the lamp, my tv did the same thing and it happened to be the lamp. Hope this helps, good luck
Aug 05, 2012 | Sony Grand WEGA KDF55E2000 55" Projection...
Need instructions and codes to program LM-1075 universal remote to Sony TV
First turn on device to be programmed. Press what device you want to program (tv) hold it down and at the same time hold power button down. Wait for red light to shut off and come back on. When light comes on remove finger device button and continue to hit power button on & off until device shuts off. Then hit stop button on the bottom off remote.
Jul 05, 2012 | Sony Televison & Video
Sep 14, 2009 | Sony KDF-E55A20 55 in. LCD Television
Tv stays on after hitting the power button and remote stops working
it prolly is turned off but the image is burned into the screen
May 25, 2009 | Panasonic PV-C2020 20 in. Combo
Problems w/ Sharp LC-46SB54U remote programming
i will help with the easiest way, hit the TV button, then hold the setup button untill the light blinks twice, then hit 991, it will flash again, hit the 1 again, then hit power, then hit the chanel up button, and if it dont shut off, hit the chanul up button again, keep going this every 2 seconds(with the chanel up button) untill the power shuts off, when it shuts off, hit the setup button again, that will lock it in, hit the power button again-TV should come back on, if that dont work, use the volum up button , after doing the first few steps, hope this helps
Jan 10, 2009 | Sharp LC46SB54U 46 in. LCD TV
Channel keeps changing
It sounds like a stuck button or switch. What happens when you hit the channel DOWN, does it still keep scrolling down?
Is this with or without the remote?
Have you tried it with the remote and or the TV?
Let me know whether you are changing the channels with the remote or the buttons on the tv and I can try to give you a couple more suggestions.
Mac =)
Feb 12, 2008 | Televison & Video
I can't find a code.
took me awhile but I figured it out
ok
Put your TV/DVD/VCR on
hold in what you want to program TV/DVD/VCR BUTTON
(you dont need codes or anything)
then while holding in what you want to program (TV, DVD, VCR) hold in ON/OFF
both at the same time
when the light comes on and stays on
keep hitting ON/OFF BUTTON
do it slow, when the TV turns off hit the STOP button at the bottom
then hit the button you just programed
then hit the ON/OFF button, the TV/DVD/VCR will turn on
if it doesnt work, repeat. make sure you hit the stop button when the TV/DVD/VCR shuts off, if you hit it an extra time while the TV/DVD/VCR is off it wont work.
took me about 30 mins to figure it out.
Feb 24, 2006 | RCA RCR450 Remote Control
Televison & Video Logo
110 people viewed this question
Ekse
RONALD CARTER JR
