Question about Bosch Washing Machines
Bosch was20160uc error - Reduced spin + Gentle Spin + Rinse, what does it mean
5 Suggested Answers
douglas smith
  • 1462 Answers
SOURCE: Bosch Axxis front loader will not drain
check filter. check no foreign objects fouling pump impellor - bra wires are the favourite
Posted on Apr 25, 2007
aborcass
Ron Coons
  • 2651 Answers
SOURCE: washing machine won't rinse or spin
sounds as if you have a faulty lid switch, for safety reasons if the machine doesnt think the lid is closed it willnot spin/drain the waer out.
Posted on Feb 23, 2009
AZEBO .
  • 228 Answers
SOURCE: Washing machine doesnt rinse and spin
IT SOUNDS AS THOUGH ITS NOT HEATING IF IT DOESNT IT STAYS IN WASH MODE AND WONT COMPLETE CYCLE NEW HEATER REQUIRED
Posted on Aug 12, 2009
barkencoa
Barry Coates
  • 3463 Answers
SOURCE: my Bosch classic 1200 express washing machine wont drain or spin
Possibly a blocked filter or pump.
Ths filter should be at the bottom right front of washer, sometimes behind a removeable cover at the bottom of washer.
To clean it, unscrew anti-clockwise, remove and clean.
Posted on Dec 09, 2009
Anonymous
  • 3 Answers
SOURCE: kenmore he2 front loader washer won't do rinse spin cycle
kappharmd-
if yours is the same, the drain is hidden behind the lower access panel on the front (how convenient, huh?). I don't understand why they didn't just make a recess hole for it. I've just left one screw loose in the center and it kinda "compression" fits. We clean this out regularly, as my wife and family don't check pockets well. :)
Posted on Apr 02, 2010
Bosch WAS20160UC/20 washing machine grinds during spin cycles. Need help determining parts for repair
remove the agitator ( top loader) and check for bra wires, coins or buttons
Jun 27, 2018 | Bosch Washing Machines
Maytag LAT8426AAM agitator only works in delicate cycle
Best guess is a timer contact problem, usually caused by advancing the timer by hand without pushing the dial in to stop the machine first.This causes burnt contacts.
Aug 27, 2017 | Maytag LAT2301AAE
Washer does not go through the spin cycle. "No
Does your machine drain water?
Usually before it goes to spin, the Electronic or Timer will first need to drain most water.
If it does not drain, clean the filter compartment (Found at the left bottom section of the door).
If it does drain water and I am wrong, please let me know, would be glad to help you.
Kind Regards
* If you found this solution helpful, please rate 4 thumbs up and leave a small testimonial. :-)
Apr 04, 2011 | Bosch WAS20160UC Front Load Washer
"LE" what's mean?
Is this a new installation?
In new installations, this error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
Step 1: Unplug the washing machine.
Step 2: While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for 5 seconds.
Step 3: Plug the unit back in, and run a rinse and spin cycle to test if the LE code is cleared.
Has a large load size been used with a gentle wash setting?
Gentle wash cycles such as Perm Press, Delicates, Hand Wash, and Wool/Silk should only be used for smaller loads. Because the cycles are more gentle while tumbling and spinning, too many items in the drum can register as an issue with the motor. In this instance reset the unit and run a test rinse and spin cycle.
Has the washer been overloaded?
Single bulky items or large loads can add extra weight to the drum and place stress on the motor. Remove some of the clothing and restart. If the issue is still present after a few items have been removed, unplug the washer for 30 minutes to allow the motor to cool and then restart the cycle.
NOTE: Make sure the drum is not overloaded
Are there soap suds visible in the drum?
Over-sudsing is the main cause of LE error codes. Using non-HE (high efficiency) detergents or too much detergent will cause stress on the motor. In addition, detergent residue can also cause leaking and odor. Follow these steps to resolved an LE error code caused by over-sudsing.
Step 1: Unplug the washer and allow the unit to sit for 30 minutes to give the suds time to dissolve.
Step 2: Plug the washer back in and press [Power] to turn on the washer.
Step 3: Do not choose a washing cycle. Press the [Spin Speed] key until "No Spin" is selected.
Step 4: Press [Start/Pause] to begin a drain only cycle.
Step 5: After the drain only cycle has completed, remove the clothing items from the machine. Turn the power back on and select [Rinse and Spin] and then press [Start/Pause]. This will remove excess soap suds and light residue from the drum. Repeat this step until no visible suds are in the drum of the washer.
Thanks for using FixYa - a 4 THUMBS rating is appreciate dof rnaswering your FREE question.
Sep 25, 2010 | Washing Machines
Code LE, will not finish the spin cycle
It's very important not only to use "HE" (High Efficiency-Low Suds) type detergent--but to use the correct amount.
Nearly all brands of "HE" detergent have incorrect dosage instructions.
The correct amount is as follows:
HE: (2) Tablespoons Per Washload
HE 2X (double concentrated) : (1) Tablespoon
HE 3X (triple concentrated): (1) Teaspoon
This reduces/prevents:
1) Musty Odor
2) "LE" Error/Interrupted Cycle
3) L-O-N-G Cycle Times (longer than time displayed)
4) Insufficient Cleaning Results
5) Small Water Leaks from the air vent behind the washer or at the
front door gasket
6) Damaged Hall Effect Sensor (on 2007 or older LG washers)
7) Reduced Spin Speeds (laundry not spin-dried effectively)
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 01, 2010 | LG WM-2277HW Front Load Washer
Error code E:13 is showing on the washer
Mine did it too on a light load. Set to reduced spin and rinse spin and everything ok. Think this code shuts washer down when spinning out of balance to protect damaging the unit.
Mar 21, 2010 | Siemens WFXD5202UC Washer
My washing machine keeps shutting off and has the letters LE in the display. What's going on?
It could also mean the hall sensor is defective and will need to be replaced.
Feb 12, 2010 | Washing Machines
Washing Machines Logo
51 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
peter gittos
peter gittos
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
