I BELIEVE ITS A CONTROL BOARD ERROR CODE
ERROR CODE DEFINITION:Communication error between the main control board module - and display control module.
WHAT TO FIX/CHECK/REPLACE: Remove power to the refrigerator and reconnect any loose or non-secure connections on the wire harness for the main control board module and the display control module.
-Remove and Replace the wire harness if faulty.
-Inspect the main control board module and the display control module if faulty.
PARTS THAT MAY NEED TO BE REPAIRED OR REPLACED: Main Control Board Module -
SEE THE MANUAL ATTACHED
SOURCE: Washer stops and signals E20 error code
Click on your model number (below FIXYA) on this website, & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
And dont forget to rate me on this great site!
SOURCE: samsung fridge RS2630SH, side by side, icing up on freezer.
You have to pull out the sensor from the board and test with tester, both sensor should read the resistance of 10,000 to 20,000 ohms. The reading that you show is very low it means that the thermistor is out of range and need replacement.
SOURCE: I own a Beko AP930
Just had this fault fixed on my 930. It is the ice sensor just under the ice cube tray - mine had a broken wire (from rotating several times a day for over a year!)
Fiddley but easy fix yourself with a "leggo" block connector to re join the wire if that is the fault, or ring Beko on 01923 654659 (very helpful company to deal with) for a part.
Part number 4344740185.
The other suggestion about the water filter I respectfully believe is wrong!
SOURCE: i have defy fridge/freezer combo c380, freezer
how long have you had this problem? I have a problem with my C440 and defy is offering me a C380 at a very reduced price. I was wondering about the relyability?
