Question about LG Washing Machines
LG Fuzzy Logic 4.0 kg WF-402A - Made mad clucking noise - like a metal bracelet in bowl - when on spin cycle.
3 Suggested Answers
Anonymous
SOURCE:
m_yuzairi
SOURCE: LG Fuzzy Logic 6.5 Kg WF-F733PC washing machine not spinning
hi...I have an LG Fuzzy Logic 6.5 Kg WF-F733PC washing machine & it's stop when 3-4 second start washing, wash and spin led appear also the buzzer bip contibuosly...any ideas?it's software problem....need advice
Posted on May 22, 2011
Lee Pinski
  • 18 Answers
SOURCE: i have a lg fuzzy logic 7.5 kg WF-T755A washing machine that has stopped spinning and also stopped agitating in washing cycle
Call LG's support line, they have excellent customer service.
Posted on Apr 04, 2013
Lg fuzzy logic 7.kg turbo drum top loader model wf-t7051td does not agitate or spin properly
I would call the washing machine engineer for a quote as there are to many things that can go wrong eric
Jan 11, 2018 | LG Washing Machines
LG Fuzzy Logic 8.5 kg washing machine WF-T855A Turbo Drum I sensor will not fully spin, stops with 2 minutes to go till end and clothes are in a ball, not spun properly,never had a problem until now??
Unplug the machine over night and then plug it back in the morning. this should reset the internal cycle back to manufacturers specs.
This problem occurs because someone may have opened the door during operations and the onboard computer recognized and remembered this, so it is now part of the standard operating proceedure.
Nov 10, 2016 | LG Washing Machines
What causes my LG fuzzy logic fully automatic washing machine model WF-T1050TP does not do washing cycle but can spin during spin cycle
it appears the motor's sensors could be going bad on it so the diagnostic computer doesnt know what to do but spin the motor in a spin cycle contact LG for a replacement motor for this washer
Sep 11, 2016 | LG Washing Machines
Lg fuzzy logic 4.0kg wf-402a wont drain
First things first, check the pump / hoses for blockage, check if the pump is operational, check outlet hose for kinks.
Apr 11, 2015 | LG Washing Machines
Lg fuzzy logic manual wf-t552th
I have an LG WF-T502C T552.
It makes a loud squeal noise on the spin cycle.
I am thinking of replacing the belt. Is it possible it could be the bearings or the transmission?
Dec 24, 2013 | Washing Machines
Apr 16, 2010 | Washing Machines
Fuzzy Logic 7.5 kg WF-T753A not agitating.
short answer, its not easy. i believe its run by a gear assembly. i would hire a pro to at least diagnois it.
Nov 06, 2009 | LG WFT1071TP Top Load Washer
LG FUZZY LOGIC
Are you sure it is the bowl and not inside the pump with the impellar hitting it on spin cycle? I just had the same problem and had to remove a dime from inside the pump.
Sep 22, 2008 | LG WFT1071TP Top Load Washer
Washing Machines Logo
121 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
