Question about LG Televison & Video
No picture but can hear sound and see picture using flash light on LG 47LN5400. Can someone tell me what needs to be fixed?
Anonymous
SOURCE:
Anonymous
  • 16 Answers
SOURCE: no picture and flashing green light
If u'r PC is OK, then this problem is showing when the main PCB of the monitor failed. This is 3 yr warranty monitor, contact the LG service provider in your area. They will change the PCB. Here is the link to get the service center info
http://www.lgservice.com/
Posted on Feb 25, 2008
localwonder
Michael Masters
  • 6784 Answers
SOURCE: Red light flashing, no picture/sound!!!!
HI, this unit has 3 main fuse links on the main board that may be blown. the fuse links should be check before you move further into the diagnosis stage. once you have checked the fuses and they are still in a working state, this will confirm a power supply board failure. this board provides and regulates the current flow and distribution of it throughout the entire unit. If the fuses are fine and the power supply board is damaged, the green light will come on briefly then, the main control will notice that the power supply is not functioning properly. Once the main control board senses an abnormal current, it will shut down the TV rendering the red light warning. The list of fuses to check are below. Remember, if they are fine and working, the issue will be the power supply board itself and, it will need to be replaced.
FUSE CHECK LIST--
3A 12v- fuse----(242208600623)
SM 3A 125v-fuse----(242208600657)
500 MA-fuse-----(242208611092)
PART NUMBER FOR POWER SUPPLY BOARD
(996500036816)
Please rate and god bless:)
Posted on Apr 13, 2009
hmantj
HmanT
SOURCE: I have a 47 inch LG model 47LN5400 and obviously the back light is no longer working. There are 3 boards, power, main, and T-con. Can anybody tell me which board I should replace?
One suggestion may be to check the ShopJimmy videos on YouTube. There is a flashlight test you can perform. I remember someone who had a similar problem as yours and they were directed toward the T-con board.
Posted on May 18, 2015
gopakumarg43
  • 76237 Answers
SOURCE: How do i fix it
The logic board is faulty. That chip can't be replaced by normal soldering techniques. Replace the board. If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Posted on Jul 11, 2015
gopakumarg43
  • 76237 Answers
SOURCE: Lg tv model 47LN5400 turns off after a few seconds, the screen lights up but doesnt even say no source....
Main board fault. Replace it. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
LG 47LN5400 blank screen after brief flash
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Dec 12, 2016 | LG 47LN5400 47" LED TV 1920x1080, 120 Hz....
LED tv LG 50LN5200 with no picture but has sound
Faulty the backlight
It is necessary to remove the panel and replace defective LEDs
Best Regards!
Oct 31, 2016 | LG 50 Inch LED TV 50LN5200 LN5200 Series...
My lg plasma TV saysvno si GB nalv has volum but no picture
Hi Kelly, The link below is a YouTube video showing how to fix a Samsung television NO picture GOOD sound, Also there's videos down the right side of the link that may help as well........CHEERS..
https://www.youtube.com/watch?v=Bf5T2wwtydY
LG No Picture Screen Flash 47LN5200 47LN5400 47LA6200 47LN5700 47LN5750...
May 01, 2016 | LG Televison & Video
I have a 55" lg flat screen tv. All a sudden i turned it on and the screen was black. You can see a little bit of it on the screen but. Very light. I tried messing with the setting didnt work.
Hi Rachel, The link below is a YouTube video showing how to fix a Samsung television NO picture GOOD sound, Also there's videos down the right side of the link that may help as well........CHEERS..
My 50 inch LG Plasma has audio but no picture. Is there a way by using the remote to reset it before I call in the technician ? Thanks
Hi James, The link below is a YouTube video showing how to fix a Samsung television NO picture GOOD sound, Also there's videos down the right side of the link that may help as well........CHEERS..
Apr 30, 2016 | LG Televison & Video
The tv has sound but no picture. For
LG LED TV has no picture (black screen) but still sound ...
www.tomsguide.com/answers/.../led-picture-black-screen-sound-fixed.ht...
My 32' LG LED TV has suddenly lost picture! The sound is all right but the Screen is pitch black. After switching it on the picture flashes for a second and then the screen goes completely black.
LCD Easy Fix (sound but no picture) - YouTube
? 4:52
https://www.youtube.com/watch?v=IBRE1Dcyxp4
Jan 13, 2012 - Uploaded by Clay Whitehead
TV Has Sound But No Picture Troubleshooting Guide - Duration: 2:30. by Repair.com 472,733 views. 2:30. LG LCD TV REPAIR -NO PICTURE ...
Dec 21, 2015 | LG 47LN5400 47" LED TV 1920x1080, 120 Hz....
Which part needs replacing on the TV? See details.
Fault to the main power supply regulator section. Either it will be on a separate board, or on the part of its main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Aug 26, 2015 | LG 47" 5400 Series LED HDTV - 47LN5400
Televison & Video Logo
104 people viewed this question
Ekse
RONALD CARTER JR
