SOURCE: Fan runs but no cool air on both freezer side and cold side
If you hear the compressor try to start then click off, you probably have a bad compressor or a bad relay. If it is less than 5 yrs old the compressor is still covered by warranty and will be replaced free of charge. The relay is only covered for a year. With it being a Maytag, I bet it is compressor. There have been a few models with control board problems that have caused this symptom, but that's not likely to be your problem.
SOURCE: Heater blows cold on one side of dual system.
it is probably the actuator located on the heater box just above the gas pedal,. it can be done just takes a little time
SOURCE: 2004 duramax dual climate control the driver side blows cold
Thankfully it was the drivers side controller! I found the temp control actuator located under the dash almost on the floor. I removed the four screws that held the cover in place then followed the wires to the actuator. removed the wiring harness then the two screws. replace with new part and heat works again!
Did you replace the sensor by the thermostat in the engine block or the one under the drivers headlight, There are two, the one next to the thermostat controls the temp gauge in the vehicle. the one under the headlight assembly controls the actual fans and is a electronic module. You have to remove the head light assembly to get to it.
Joe
SOURCE: Frigidaire Side By Side Not Cooling
That sounds like the start relay is buzzing. Unplug and lets check the compressor to see how hot and if too hot to hold your hand on the top of compressor we need to leave it unplugged until we find out if the start relay, start capacitor, overload or if the condenser fan stops after running a short while. Sea Breeze
