Question about Black & Decker Drills
Does a Black & Decker 3/8 variable speed drill number 7120 go clockwise
    Top Expert:
  • Black & Decker Master
  • 34,541 Answers
All drills go clockwise
Posted on Dec 23, 2019
I have a black and decker rotary hammer drill i can only read 3 numbers of the model it is 045 but its the last three sn number 0481121 under pat 3309541 need parts manuel for
Your one sounds like this one
http://www.ereplacementparts.com/black-and-decker-5045-type-100-rotary-hammer-parts-c-4167_7879_17406.html
However there are three variants on this page.
http://www.ereplacementparts.com/black-and-decker-hammer-drill-parts-c-4167_7879.html
Black and Decker Hammer Drill Parts ' Great Selection ' Great Prices ...
  1. Cached
  2. Similar
Black and Decker 22738 Type 1 1/2-Inch Hammer Drill Parts. 22738 Type 1 Black ... Black and Decker 27106 Type 1 3/4 Rotary Hammer Parts. 27106 Type 1 ...
Black and Decker 5045 Type 100 Rotary Hammer Parts
www.ereplacementparts.com/black-and-decker-5045-type-100-rotary-hammer-parts-...
  1. Cached
  2. Similar
Black and Decker 5045 Type 100 Rotary Hammer Parts .... Drill Parts Hammer Drill Parts Rotary Hammer Parts. Search within model. SEARCH. Discuss ' Repair ...
Black and Decker Hammer Drill Parts & Repair Help ' Fix.com
https://www.fix.com/parts/power-tool/drill/hammer-drill/black-and-decker/
  1. Cached
Shop for Black and Decker Hammer Drill parts today. Find genuine replacement ... (Type 100). Variable Speed Reversible Rotary Hammer · 5014. (Type 100).
Black and Decker Parts - Tool Replacement Parts ' Tool Parts Direct
www.toolpartsdirect.com/brands/blackdecker.html
  1. Cached
  2. Similar
Black and Decker Drill & Driver-Drill Parts · Black and Decker Hammer Drill Parts ... Black and Decker Rotary Hammer Parts Model Schematics and Tool Parts ...
Black and Decker 5043K_TYPE_3 ROTARY HAMMER KIT Parts ' Tool ...
www.toolpartsdirect.com/blackdecker-5043k-type-3-rotary-hammer-kit.html
  1. Cached
Find the Black and Decker blackdecker_5043K_TYPE_3 ROTARY HAMMER KIT parts you need at Tool Parts Direct. Shop thousands of Black and Decker ...
Black and Decker Rotary Hammer Parts ' Tool Parts Direct
www.toolpartsdirect.com/hammer/rotary-hammer/blackdecker.html
  1. Cached
Replacement Black and Decker Rotary Hammer Parts online. Tool Parts Direct has thousands of Rotary Hammer Parts to fix Black and Decker tools. Shop by ...
www.toolpartsdirect.com/hammer/rotary-hammer.html
  1. Cached
  2. Similar
Tool Parts Direct carries the largest inventory of replacement Rotary Hammer Parts for thousands of make and models. Buy Rotary Hammer Parts online for all of ...
Black & Decker Replacement Parts - 1800ToolRepair.com
https://www.1800toolrepair.com/tool-repair-parts/black-decker
  1. Cached
Black & Decker replacement parts for all Black & Decker tools. ... Black & Decker Cordless Circular Saw Parts ... Black & Decker Electric Hammer Drill Parts.
Beyond Parts - Black & Decker ServiceNet
servicenet.blackanddecker.com/Parts/Detail/29096
  1. Cached
  2. Similar
Available, Add Parts to Cart ... Model #, Model Description, Parts Diagram. 5041K Type 1 · MACHO I ROT HAM KIT · 5042-09 Type 1 · HD ROTARY HAMMER.
black and decker rotary hammer drill Google Search
Dec 25, 2016 | Rotary Drills
Black & Decker Q200 not variable speed now??
if you took it apart to change the chuck you might have disconnected some wire id check that first
May 29, 2012 | Office Equipment & Supplies
My DR201 works great in the LEFT (clockwise) setting but NOT in the RIGHT (counter clockwise) position. It will occasionally work in the RIGHT position, but is intermittent. It has always functioned this...
All you have to do is take the model number and go to Sears to order a trigger switch. Take the cover off of the drill, take the wires off the old switch, and put the new one in. It is super simple.
Mar 22, 2011 | Black & Decker 3/8" Variable Speed...
Black & Decker 1/2" drill
I had to replace the variable trigger on my 3/8 Black and Decker as the trigger failed and would not start the drill.Maybe you have the sme problem as many B&D drills have the same variable trigger.
Jan 10, 2011 | Drills
I NEED A WIRING DIAGRAM FOR THE SWITCH ON AMODEL 7191 TYPE 3 , 3/8 B&D DRILL
i don't think you will find a diagram for the switch. find a parts schematic and order a new one. they aren't make to be fixed.
Aug 02, 2010 | Black & Decker 3/8" Variable Speed...
How do I change my black & decker electric drill to go in reverse or forward? As you can see I'm tool challenged. Kathleen
The switch near the trigger that toggles left or right controls that.
Good luck with your project, Kathleen.
Oct 02, 2009 | Black & Decker 3/8" Variable Speed...
Keyless Chuck how do you change the bit? Model
hold outside collar on chuck firmly with your hand and reverse drill
Jul 10, 2009 | Black & Decker 3/8" Variable Speed...
How to change the drill bit
there is a rippled edge close to the very tip of the drill and there is a key supplied with the drill with the corresponding ripples place key into the hole near tip of drill so ripples meet each other and turn key in an anticlockwise direction to loosen put in new drill bit re tighten in clockwise direction hope this helps if not please ask for more info glenn
Nov 23, 2008 | Black & Decker 3/8" Variable Speed...
Drills Logo
54 people viewed this question
Top Black & Decker Drills Experts
JOHN LAPIER
Marvin
Marvin
Thomas F. Schneider
Are you a Black & Decker Drill Expert? Answer questions, earn points and help others
