You might call customer support for Ematic and inquire about this. Nougat of course is an android OS.
https://www.androidauthority.com/install-windows-on-android-868800/
SOURCE: Tablet not connecting to Wi-Fi; router is NETGEAR WNR 1000
Try changing your wireless encryption settings, the type of security it uses can sometimes be an issue.
Here is a detailed guide on how to access your routers settings: Netgear WNR1000 wireless settings guide
Try to fine out what is defect the charger, the cable, or the tablet, by testing other cable, charger and tablet. not all 3 the same time, but one at the time.
SOURCE: I crack the screen on my ematic tablet an it won't
I'm afraid, till you have another screen it wont work correct again. Goto a phone / tablet repair stop and ask them what it will cost you if they replace the screen. If you like the price they are asking, use their service. If it is to expansive, start saving for a new tablet. and perhaps a screen protector too?
rstech_teni is in your tablet as a core system app even though it may be no such thing. I believe it was put there by the tablet
manufacturer in some contractual agreement with some advertising entity. The Lookout malware scanner may sometimes detect it as malware you should just ignore it and not try to delete it, as it will result in your problem again.
You will not be able restore the tablet from the hardware restore menu (hold power & up vol) because it will not allow you to answer "yes" to the prompt to proceed.
Two ways to fix, (Later, on how to actually select something)
1. (preferred)
Go to >Settings >Apps >All
scroll down to rstech_teni, select it, and then select "Clear data"
If you don't see retech_teni you may find "rs_9104_v30". This may be a clone of rstech_teni, do the same to it.
Your done.
2. (last resort, you will lose installed apps and data)
Go to >Settings >Backup & reset >Factory data reset,
Follow instructions, and your done.
And now the hard part, to deal with the message that will not let you navigate.
The easy way to get to "Settings" is to short tap power button to put tablet to display off/locked.
Then again short tap to turn on screen. You will see the rstecc_teni MSG hit OK in MSG. The MSG should be gone and not come back, do nothing else other than pull down the right upper drop down menu where the settings button is then select settings. At this point the evil MSG will come back.
From here on the frustration will start.
You will need to use two hands. Tap the rstech_teni OK with one finger on one hand and then quickly tap the Apps option with a finger on your other hand. This is kind of time consuming but it works after multiple attemps.
If you have a stylus pen, use it for the second tap to the option you want. It will seriously reduce the time it takes by making the second tap very accurate.
Within a half hour you should be able to get through this.
I know because I had the same problem.
SOURCE: Bought a ematic 7" HD quad core tablet screen crack bought on 12-24-2015 is it still under warranty
These companies do not make returns for cheap tablets easy ,lessons learned .
