no there are no repair for regulator safety regs do not permit it. what is this tower can you go from propane tank to stove? type in search engine 2 stage regulator for propane tank. There be several returns. I personally would not buy bottom end regulator.
When converting from natural gas to propane you have to switch the regulator to propane. then on most modern stoves you have to turn the orifice hoods down to adjust for the higher pressure of propane. there are some stoves that you have to purchase a propane conversion kit with different orifices for the burners and oven burners.
You can change a natural gas stove to propane or go the opposite, but you cannot make an electric stove into a gas stove. You will need to buy a new stove if you want to go that route. Sorry.
Reinstall propane with fresh full propane canister. If problem persists then check tubing in stove for blockages. Make sure you open valve all the way for lighting.
If this doesn't work you may have a defective unit and need to replace it or send it for repair.
the fuel to air mixture is set incorrectlty or your pressure at the ouitlet for the gas valve is too low.
you culd play around adjusting the first part of this but for the gas valve part you have to have a manaometer to check it out correctly. then it should be set at 10"wc. Good Luck
The burners are working only as a fluke. It is extremely dangerous to operate a natural gas stove on propane. STOP USING IT IMMEDIATELY. Call your local propane supplier and ask them about converting it to LP/Propane.
