THat is out of my league with no more info than that. What are you trying to get the fire stick to do? If it says no signal you areputting it in a ouotput port I would say. Make sure it isa input port for HDMI. Let me know eactly what you are trying to do. To be honest, I don't kow what a fire stick is supposedto do
SOURCE: HDMi ( no signal, not supported) doesn't work with Dmr
I have lost my manual for the lct27ta. Have you gone into the menu and setup the hdmi port?
SOURCE: HDMi ( no signal, not supported) doesn't work with Dmr-Ez47v
Return set!
Akai Tv is not HDCP compatible. Nothing worked akai was not very helpful. This model , a 2006. aparently will not communicate will the newer HDMI devices.
RETURN SET IF POSSIBLE. NO SOLUTION FOR THIS PROBLEM!
SOURCE: No sound through HDMI port on rear of tv
You could replace the HDMI port on the TV, it's no different than changing a USB port card in your computer. But, finding the replacement HDMI port card for your TV can be tough. Try shopjimmy.com for parts.
SOURCE: Sceptre X37sv-Naga 37 HDMI port is not making contact
hd EZ lock by Blue Echo Solutions is a Universal HDMI Locking Adapter, the only one on the market. It works with most HDMI Cables and components and attaches to your component's chassis, using the existing screw above or below your HDMI Input or with the supplied adhesive. It supports your HDMI Cable from the component's chassis, eliminating stress on your HDMI Input and keeping your HDMI Cable in place. www.blueechosolutions.com
SOURCE: my hdmi port is not working
I have Verizon Fios and there's a known issue with the motorola HD boxes that they have bad hdmi ports, the screen goes green and that's it, nothing I can do about it I just use component cables. You need to be sure it's your tv not the cable box. Try the hdmi on a dvd player or ps3 or whatever else you have first just to be sure it's the tv at fault not the cable box. If you determine it is the tv you need to replace either the main board or the video board depending on your specific tv model. Some have the video inputs on the main boards some have video boards.
