Question about Coffee Makers & Espresso Machines
My K150P says Water Flow Interrupted To reset, press Brew button (which is blinking). Does not reset. I’ve unplugged and cleaned needle. Can you help?
    Top Expert:
  • Coffee Maker... Master
  • 30,467 Answers
Need to fix the water flow. See the videos
https://www.google.com/search?q=K150P+says+Water+Flow+Interrupted
Posted on Dec 07, 2019
6ya staff
SOURCE:
Anonymous
SOURCE: The coffee maker won't brew.
short circuit
Posted on Jan 04, 2008
mirran
Mirko Blas
  • 515 Answers
SOURCE: saeco SUP 021 (Y)
is it the far right lamp that blinking? Then you have to descale your machine.
Is it the lamp in the middle in the bottom row, then you have to open the door and take out the driptray and dregsbox for 5 to 10 sec.
if the water drop flashing then you have to open the steam knob and make a cup of water(tea).
Hope this will help you.
/Mirran
Posted on Aug 23, 2008
MSDLF1
SOURCE: Mr. Coffee won't brew - Mod. #ECX30118
I know this sounds crazy but I just did this to mine & it worked! Mine would get power & allow me to set the clock but the brew now button would not work & I could not set the timer for delay brew. I admit, I was pissed, so I poured out the water & pounded on the base a little... I hit it a few times & banged it a few more while unplugged... plugged it back in & I pressed brew now & brewed! Then I dumped it out & set my time, delay brew timer & I am in business again!!! An internal wire was probably shifted out of place or something ridiculous because I never had any problems before this but it has been sitting a while. There is no other fix unfortunately because this model is outdated & they no longer postthe instructions or troubleshooting online. I have the same exact model. Good luck!!!
Posted on Jan 28, 2009
Anonymous
SOURCE: It says it's brewing - - But It is Not???
If it won't pump water through, how are you going to run a descale? Also this model is supposed to tell you if scaling is an issue. We called Keurig, they said, we will send you a new one.
Posted on Mar 25, 2010
BarrettDenCo
Barrett Palumbo
  • 1772 Answers
SOURCE: does not brew coffee consistencty,
Sorry to read about your issue.
The brewer should be de-scaled at least every 3-6 months. Scale is harmless, but if left unattended, it can hinder optimal brewer performance. De-scaling your brewer regularly helps maintain the heating element, removable water reservoir and other parts of the brewer that come in contact with water. Better water quality and water heating means a better cup of coffee, tea, hot cocoa or iced beverage. We recommend de-scaling your brewer at least every 6 months (every 3 months if your water has a high mineral content). The de-scaling process involves using 48 ounces of undiluted white vinegar.
Take 48 oz of white vinegar. place in tank. pretend you are making coffee (Do No Use K Cup). let the water fill you mug. then empty that mug. Do it again until tank is empty. then let sit for 4 hours.
Then fill with fresh water to the top. let that tank of water run thru. towards the end taste the water.
If you taste vinegar..use more clean water, until the taste is ok.
I tried to help you. Please help me and Vote/Rate this response. Thanks and good luck
Posted on Dec 22, 2010
Hi there, I just purchased a Jura S9 One Touch. I've used it for a week, maybe making 10 coffees/day. Just yesterday an ERROR 6 message popped up. I don't know what to do, please help?
Hi, Error 6. Haven't come accross that one before. It sounds like brew unit problem.I do know error 7&8 are brew unit problems and 1 to 5 are water flow and heating errors. Try turning off the machine at the main power button and unplug it from the wall for a few minutes. This will reset the machine and right it self. They can do this from time to time. Dazza
Sep 23, 2011 | Jura Capresso Impressa S9 Coffee...
My B70 does not brew anymore. I've had this problem with two other B70's which I returned. I've been able to nurse this third one along, but it finally gave up. When I press the brew button...
This is a common fault with these as the pumps rust very easily which causes them to seize.
Depending on your technical ability you could try and strip the unit and either clean or replace the pump.
I can't find any further information on a replacement pump for this model but if you do decide to strip the unit you should be able to get a Model No off the existing pump which is more than likely an ULKA..
Here's a link to instructions how to strip the unit.
http://www.singleservecoffeeforums.com/dissassembly-repair-guide-keurig-b70-platinum-t8124.html
If you need any further assistance then just ask.
Jun 23, 2011 | Keurig B70 Coffee Maker
I set the brew size on the Keurig, but can't figure out how to get the lights to stop blinking and make the coffeemaker actually brew me a cup of coffee. I've held down the brew button, thinking that would...
the blinking blue lights, means the water level is low...BUT sometimes it sticks, if the tank is not clean..its that round disk, on the side of the water tanks that sticks..try resetting the tank..set set the default brew size..goto menu, then goto brewsize to set the default size...when it says ready to brew..then you can select the size...
Dec 18, 2010 | Keurig B70 Coffee Maker
Cleaned my mr coffee pstx properly and the light will not go off . Unplugged it and everything help !!!
!!!!FIXED!!!!
I know this an old question, but I finally fixed mine. Hopefully this will help someone. I have a PSTX Mr. Coffee (10 cup) maker.
Allow me to provide some background first ...
I started a clean cycle, following the instructions in the booklet exactly. I used 4 cups of white vinegar and pressed the clean button. Easy, right? The reservoir emptied about 2/3, the clean light began blinking and an audible (steady) alarm sounded. I waited for 2 hours for that audible alarm to stop, but it never did. Finally, I unplugged the coffee maker, plugged it back in and tried again. Same results. By this time, I figured I had run enough vinegar through it to properly de-calcify the unit, so I repeated the "clean" steps numerous times with just plain water. Same results. I realized that I could still brew coffee; only thing is, the darned clean light would keep coming on when I pressed brew. Surely, I did something wrong or there would be an answer on the web. I searched many answers, but none fixed my problem. So I decided to call Mr. Coffee (US: 800.672.6333 or Canada: 800.667.8623). I navigated through the menu and found the troubleshooting section for cleaning. The automated voice said, "Place 6 cups of cleaner solution or white vinegar in the reservoir...."
Stop the presses! Did she just say 6 cups? The manual clearly states 4 cups. Also, that's what everyone else on the web is reporting.
So I tried it, and I only used water (since the pot was still relatively clean) - 6 cups of water - pressed the clean button. This is what you SHOULD expect:
1. Place 6 cups of cleaner solution or white vinegar in the reservoir
2. Press the "clean" button.
3. When approximately 2/3 of the solution has brewed through, it will [apparently] stop brewing - the "clean" light will begin blinking (but there should NOT be any sort of audible alarm) - let the maker sit; it's still working on the clean cycle.
4. The final 1/3 of the solution will brew through and the cleaning light will shut off.
This CONCLUDES the cleaning cycle.
Of course, you should just perform a few "regular brew" cycles with just plain water to clear out the vinegar (or cleaner solution) odor.
Bottom line: The manual screwed all of us! 6 cups, not 4!
Try it - Hope it works for you as well as it did for me.
John
Nov 16, 2010 | Mr. Coffee 072179228578 12 Cup Coffee...
I have the Keuirg mini plus and i just opened it. It flashes red like it is heating and then just turns off. No brewing.
Same here. (I have the Mini Plus B31) Called Keurig and these are the steps they walked me through. Not sure which part actually fixed the problem, but it worked.
1. Turn off machine. Using a paperclip clean out the holes in the needles (3 in the top, one in the bottom of the k-cup holder).
2. If water is inside the heating core (assuming it is as nothing happened when you tried to brew), with the machine turned off, press and hold the brew button. After 5 seconds the pump will kick on and discharge the water. Make sure you have a cup in place to catch the water.
3. Dispose of that water.
4. Unplug the machine.
5. Wait 5 seconds.
6. Plug machine back in.
7. Turn on.
8. Run empty cycle without a k-cup and only use the minimum amount of water (6 oz).
9. Dispose of that water after it brews (hopefully).
If still nothing is happening, call Keurig.
10. Brew your coffee, tea, choco, etc.
Note: was told by Keurig rep that whenever you use hot chocolate, to run an empty rinse cycle afterwards before brewing another cup. This will help prevent any choco from going up inside the machine and possibily blocking the water flow.
Hope it works! Mine did after following these instructions. The rep also wanted me to measure the amount of water that came out afterwards. Not sure what the next step would be because my call got dropped, but the machine works. Sipping on a cup now...
Oct 16, 2010 | Keurig B60 Coffee Maker
Keurig Special Edition that will not brew
all the lights are blinking its clean, descaled, filled with water and the power button and all the buttons just blink and it wont brew just had this machine less than 6 months and the machine will only quit blinking when i unplug it and yes ive tried different outlets when i plug it back in all the lights start blinking again and it wont brew i want a solution to this problem and i dont want to be sent to another site where they charge me to answer a question the $119 i payed for the thing should be enough im ready to throw it out the window im so frustrated with it
Mar 17, 2010 | Keurig Special Edition B60 Coffee Maker
After the coffee is ground and pressed, no water goes through to brew the coffee and dispense it
Sounds like the brew unit is blocked, to be sure try this, use the pre grounds button to brew a coffee, if no water comes out then it is the brew unit, remove unit and look under red o-ring, you will see a shower screen, clean shower and tube that flows to the discharge(top, you will have to remove the 2 screws up there, be careful not to lose the small plastic ball under the spring). Reassemble and try again.
Jan 18, 2010 | Gaggia Syncrony Logic 74884 Espresso...
Do not know how to program fresh start oasis full button over fil
Remove the brew basket and water defuser (sprinkler head) it should come off with a 1\2 turn.
Place your measuring pitcher or empty pot in place.
Turn the main power switch off in back of unit.
Press and hold the Brew(full pot) button.
While holding the Brew(full pot) button turn the main power button in back to on.
Once the red light flashes over the Brew(full pot) button release it, then press it once to start the brew cycle.
Let it flow until desired level in pot or measuring pitcher.
Press the Brew(full pot) button once to Stop.
Press the Brew(full pot) button once again to lock the settings into memory. Memory will store the settings even if machine is unplugged.
Half pot button is automatically set.
Apr 09, 2009 | Oasis FreshStart 80 oz 10-Cup Coffee Maker
Keurig B70 Not Ready Message
Unplug the unit for 20 seconds- 1minute. Plug it in again. You should be able to program from the menu. Hope this works.
Feb 12, 2009 | Keurig B50 Coffee Maker
Coffee Makers & Espresso Machines Logo
42 people viewed this question
Top Coffee Makers & Espresso Machines Experts
ThaMp3Doctor
ThaMp3Doctor
Pierre Laplante
Marvin
Marvin
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
