Refrigerators Logo
Brenda Leahey Posted on Dec 07, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Samsung Fridge model RF217ACWP will not reset after power outage. Tried unplugging still will not work.
Shawn Snile
Level 2:
Habit-Forming:
Scholar:
  • Expert 61 Answers
  • Posted on Dec 07, 2019
Shawn Snile
Expert
Level 2:
Habit-Forming:
Scholar:
Answers
61
Questions
0
Helped
6780
Points
135
Hold down "Energy Saving" and "Lighting" buttons simultaneously for 10 seconds (or top left & right buttons). Display panel returns immediately. Or try pressing the power freeze and vacation buttons for about 3 secs and it worked great.
5 Related Answers
Anonymous
  • 208 Answers
  • Posted on Dec 20, 2007
SOURCE: How to correct error message sram error missing E?
Hate to say this but most likely the Print Engine Control Board has failed.
Anonymous
  • 619 Answers
  • Posted on Jan 09, 2008
SOURCE: Maytag washer not reset after power outage
The magnetic switch was stuck due to power outage / contactor are spark connect the contactor stuck together .Magnetic switch to replace.
Anonymous
  • 750 Answers
  • Posted on Sep 29, 2008
SOURCE: fridge/freezer not cool.
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
I believe your problem is an old thermostat or compressor !
How old is it?
My advice is do not put good money into bad!
A new fridge will pay for itself in a few years by using a lot less electricity!
Here is an interesting report I just read!
Repair or replace?
When to pull the plug on your old refrigerator
It nearly always makes sense to undertake simple do-it-yourself repairs,
such as replacing a gasket on a refrigerator or a freezer.
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your refrigerator,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your refrigerator is under warranty or less than four years old (three years for top-freezers),
paying for a repair makes sense.
Note that refrigerators under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your refrigerator is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models are quieter and have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new refrigerator.
Data also shows that it doesn't pay to fix a less-expensive top-freezer refrigerator
six or more years old or a bottom-freezer or side-by-side eight or more years old.
Thanks to better recycling programs, less than 10 percent
of a refrigerator you replace is likely to end up in a landfill.
Thanks for giving me the opportunity to help!
Please remember to leave me a rating before you sign off!
Thank You, HUUUM
Anonymous
  • 1122 Answers
  • Posted on Mar 15, 2009
SOURCE: Whirlpool Fridge Freezer not working fridge is
ID THERE FROST BUILDING UP IN THE FREEZER?IKE
Anonymous
  • Posted on Feb 12, 2010
SOURCE: Samsung RB1855SW won't stop beeping and fridge malfunctioning
Thanks so much for the advice. I just gently pried the door sensor switch on my Samsung RB1855SL out with a butter knife and then pulled out the electrical connection and it fired up right away. It looks like some orange juice seeped in and corroded it. What a relief to have the fridge working again, not to mention to not have to listen to the beeping.
My Samsung fridge is flashing 33 E, 26 E and 8 E. I've tried holding down the top left and right buttons to reset; however, nothing happens. How can I fix this?
https://removeandreplace.com/2015/08/10/samsung-refrigerator-error-codes/
A power outage will make your Samsung fridge show the errors 1E and or SE. If this is the case, simply press the power save and lighting buttons for 10 seconds and the error will clear. OR... press the fridge and freezer buttons at the same time for 10 seconds to reset the control panel and clear the error code.Dec 10, 2016 https://removeandreplace.com/2016/12/10/samsung-refrigerator-flashing-blinking-faults-reset/
https://www.youtube.com/watch?v=4XW0fW9NjGU
Hi there I have a Samsung model SRL551DP upside down fridge. Recently our whole block had a power outage. When power restored fridge did not resume. Refrigerator door panel blinks the letter d only?
modern fridges do not like power surges as it burns the electronics
call in a technician to check it out and put a surge protection in the power supply cord
Model RB215LABP reset temperature display after power outage
Samsung Blinking Dash/Line Error Code List - Parts Dr
https://partsdr.com/blog/samsung-blinking-dashline-error-code-list/
Jul 16, 2011 - Indicate Error when the temperature sensed by Refrigerator sensor is .... My model required holding the super freeze and super cool buttons, but it worked! ... My display said S and E after a power outage I pressed energy .... I had that 5 E error code after a brief power outage... thank you for the resetting ...
Samsung Refrigerator Troubleshooting Self Diagnostics ...
www.appliancerepairlesson.com/.../samsung-refrigerator-troubleshooting...
Apr 13, 2011 - and then I also noticed that the display buttons for the temperature is not working. ..... We have tried to reset the refrigerator with no luck. ..... I had a power outage yesterday and my Samsung Fridge RSG257 now shows an 88 .... I haveModel# RF268ABRS, this thing quit cooling/freezing after we lost power.
Error Codes / Messages / Blinking
2helpful
Our fridge compressor won't run after a power outage, can it be reset?
compressors use a small start / run capacitor to start the compressor
modern fridges do not like spikes from power outages and many power boards and electronic components fail because of this and I am inclined top use a surge protector before the fridge cord plug
I went google and typed in --fault code 88-88 for samsung fridge model rf26aewp and the first site up is error codes /messages/ blinking
the site is support-us.samsung>popup>iframe
there is a detailed answer there with a list of fault codes as well and what they indicate
there are other sites that also refer to the fault that you have
2helpful
We have a Samsung RS265TDWP side by side refrigerator. After multiple power outages last night in storms, I discovered this morning the temp on the fridge is 53. I have tried unplugging to reset. Did...
Being a newer fridge I would look at the control board being faulty. They do not Handel porters surges very well and you may have blown a relay or resistor on the board. I would install a surge protector on anything you own with electronics in the future.
I had the same problem everyone else is having with my samsung model RS2534WW refridgerator. After a power outage the freezer failed but the fridge worked fine. Then another outage and both sides quit...
I had a similar problem also after a power outage, I called best buy for service and 200 bucks later it was a no go, same problem. I found a repair manual on the online auction place E b a y and was able to troubleshoot down to a faulty relay on the PCB, look there for the manual it may help you. I is not the compressor cause then the freezer would not work also.
1helpful
3answers
My model rs2555sl samsung fridge does not start up after power outage.
Samsung RS2555Sl suddenly stoped working once the power is switched off, If switched on again, only the Ice making sensor light flickers. If both Pwercool and power freeze buttons are pressed for 12 seconds it stars and running normally. Will it automatically start working if I change the Ice making sensor?
Refrigerator will not reset after a power outage
just unplug it wait 5 minutes and plug back in. If this doesn;t work, replace the mother board.
David
49helpful
7answers
Control panel not working Samsung refrigerator model rs2533sw. Not cooling.
I have a samsung refrigertor rs2555sl and my control panel stopped working after I turned the power off to the house (to install a light fixture elsewhere). There was one green light blinking on the refrigerator temp display.
Hold down the "power freeze" and "power cool" buttons at the same time for at least 8 seconds. This is a self diagnostic program. A number should appear on the refrigerator temp display (1-9)...it will hold for 30 seconds and then the panel should function again.
In my case the number that appeared was "3" which can indicate a multitude of things including a short circuit or power outage (which was it was for me).
Hope this helps!
Top Samsung Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
