Tools & Hardware - Others Logo
Skot lawrence Posted on Dec 07, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi, I tried to use my belt/disc sander on it’s side so the belt was vertical. After 10 seconds, smoke poured out of the motor. Put is back to original position, worked fine. Tried it on it’s side again, same result, ran ok for 10 seconds, then smoke. Anyone know why? Can’t find a single answer on the internet.
ChinthakaJ
Level 3:
  • Master 943 Answers
  • Posted on Dec 07, 2019
ChinthakaJ
Master
Level 3:
Answers
943
Questions
Helped
301522
Points
2783
The lubrication (oil) for the belt rollers may be dripping in to the motor and burning up.
5 Related Answers
Anonymous
  • 2961 Answers
  • Posted on Sep 06, 2007
SOURCE: Insignia DVD/Cassette combo player
I imagine you have checked the disk for scratches top and bottom, if so you can purchase a cd/dvd lens cleaner cdrom as the laser may need realigning and cleaning.
Anonymous
  • 3 Answers
  • Posted on Oct 08, 2008
SOURCE: belt sander adjustment
There should be a knob on the front of the sander which adjusts the front roller on the sander. If the belt runs off in the same direction each time try turning the knob as the sander is running and while watching the belt. If turning the knob one direction does not work try turning the other direction. If turning the knob does not have any affect on the way the belt tracks on the sander then you probably have a broken or missing part on the front of the sander. This may require taking the sander to a service center.
Anonymous
  • 29 Answers
  • Posted on Nov 06, 2008
SOURCE: Dremel belt/disc sander
see the manual
Anonymous
  • 23 Answers
  • Posted on Dec 10, 2008
SOURCE: makita gv5000 5" disc sander won't work
there isn't an internal fuse. by the sounds of it you probably have a short, a bad brush, or some arcing.
if you use your sander for fine sanding (100+ grit paper) you have to make sure to clean out the motor housing. Fine sanding dust, like any fine dust, creates alot of heat when aerated and can melt the plastic brush holders or can cause the electricity to arc from one wire to another inside the housing.
my advice is to take the 8 (i think it's 8) screws out of the side of the gun and carefully pull the halves apart. there isnt alot you can mess up inside and just visually inspect the wires for burns or melting on the brush holder.
here's a breakdown if you need it.
http://www.makita.com/en-us/Assets/images/Products/_PartsBreakdowns/PB_GV5000.pdf
if you find something inside that you're not sure of, or if you have any additional info i'll keep checking in on this.
Anonymous
  • Posted on Jan 06, 2009
SOURCE: 2004 Saturn Vue - Getting Rear Seats Back To Upright Position
Push down on the seat then pull the handle or both at the same time then pull up while holding the release up, it got me at first, but thats how i got it
I need a motor for my Dayton model 6y001 belt/disc sander.
https://www.grainger.com/product/DAYTON-Belt-Disc-Sander-49G990 http://hainisxyness.gotdns.ch/forum/?q=Dayton+Belt+Disc+Sander+Manual
Change a disc on the 5" sander on the belt and disc sander item 10027
please be more specific!!
guessing - bench top disc/belt sanders' discs usually use stick on backed sand paper discs ;)
How to fix motor delta belt disc sander
What is it doing or not doing, when u turn on the switch, either the switch or motor is probably bad or you have too much tension on the belt.
1helpful
2answers
I have a Black & Decker sander, model # 7447 and am having problems changing the sand paper.
The 7447 does not have a release lever. To change the belt, you must release tension of the rollers by pushing the front roller straight back until you hear it click and lock in position to change paper. Remove old paper and replace with new paper. Make sure if new paper has directional arrows to install properly.
Now you must release the front roller to put tension on paper. To do this push the front roller from the side that has the adjustment screw. This will release the front roller and allow it to go back into position. Be careful as it pops back quickly and with some force.
Turn on sander and adjust centering of paper with adjustment screw found near the front and side of sander.
I have an old craftsman belt sander that needs oil because the engine has started smoking. I bought the right oil, but can't figure out where to put it in. Help?
Many belt sanders have sealed bearings that are packed with grease at the factory. They require no further lubrication. Sleeve bearings should be lubricated with 30 weight oil or an equivalent after each 10 hours of use.
Only about 2 to 3 drops of oil should be applied to each sleeve bearing. Avoid using too much oil. It can get on the work piece or on the belt and the belt will slip.
My delta sander stalls while sanding on the belt.
Mine was underpowered from the get go. I have since sold it. Keeping it well lubricated does help though.
Electric Bosch hand held orbital sander belt not rotating properly
My guess is that your sander got gunk in the belt and other rotating parts and you are either burning up the belt, or (hopefully not) the motor windings. Rick
Top Sander Tools & Hardware - Others Experts
vince
Ngoro
Are you a Sander Tool and Hardware - Other Expert? Answer questions, earn points and help others
