Depress the alarm button for 3 seconds.
User Preferences:
• Activate or turn off Super Cool (select models) • Change the temperature display from °F to °C
• Enable or disable audible alarms. • Adjust the light level at which the Dispenser Auto Light will illuminate (when this feature is activated on the ice and water dispenser) (select models)
• Activate the Sabbath Mode To access the User
Preferences menu, press and hold the Door Alarm pad for three seconds. When in the User Preferences mode, a short title for the feature will appear in the Freezer temperature display and the feature status will appear in the Fresh Food display.
SOURCE: Disconnect Audible Alarm
Sorry but some models cannot shut off the alarms. The newer models can.
SOURCE: HOnda Accord EX 1998 ALARM
Have you tried putting your Valet (original keys) into the ignition and turning it to the II position?
SOURCE: Fisher & Paykel ED56 Dryer alarm on. Nothing else works
Replaced electric control panel. Looks like power spike fried the works
SOURCE: Beeping noise
try shutting the power off to the unit, tere is an on/off switch behind the top grill. It will reset the control board.
SOURCE: The Alarm keeps buzzing to my Jenn Air ww2780w
Defective touch pad or clock (ERC)
Replace touch pad or clock (ERC). Touch pad is a more common problem.
You can use the test procedure below to narrow the actual issue.
This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Sure Alarm battery Back-Up System
This SmartSet® Clock Radio includes a Sure Alarm battery back-up circuit that can
wake you up even if the power is 'Off'at the selected wake up time. If your power
is 'Off'at the selected wake up time the clock display will be off and the radio will
not operate, but a separate mini-buzzer will turn 'On'automatically to wake you up,
even if you had selected the "Wake to Radio"option.
The Sure Alarm will sound for 30 seconds and then shut off automatically.
To stop the Sure Alarm buzzer immediately, press the RADIO ON/OFF button.
Pressing the SNOOZE button has no effect during Sure Alarm operation.
Note: In order to maximize the life of the built in lithium battery, please be sure
to set the ALARM 1 and ALARM 2 switches to the "OFF"position if the radio
will be disconnected from the AC outlet for more than a few hours. This will
prevent the Sure Alarm from turning 'On'unnecessarily.
1.) Depress and hold either the ALARM 1 or ALARM 2 setting button.
The display will change from the correct time
to the Alarm 1 or Alarm 2 wake up time.
2.) While holding the ALARM 1 or ALARM 2 setting button, depress either the
SET + or - button to move the display ahead or back to your desired wake up
time.
3.) When the desired wake up time appears on the display, release the SET + or
- buttons.
Note: Be sure that you have set the wake up time correctly by observing
the AM indicator. If the AM indicator is 'On'the wake up time is "AM". If the
AM indicator is 'Off', the wake up time is "PM".
4.) When the desired wake up time (AM or PM) appears on the display, release
the ALARM 1 or ALARM 2 setting buttons
