Dishwashers Logo
PETER J DELAURIER Posted on Dec 05, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
GSM1800NWW GE 18 Dishwasher Won't Drain. I've eliminated all the likely problems. There is no apparent blockage from the drain filters to the sink drain. The drain pump fires when hot-wired.
Dan Apthorp
Level 2:
Passionate:
Visited the website for 10 consecutive days.
Habit-Forming:
  • Expert 69 Answers
  • Posted on Dec 10, 2019
Dan Apthorp
Expert
Level 2:
Passionate:
Habit-Forming:
Answers
69
Questions
0
Helped
17303
Points
166
Could one of the hoses be buckled?
5 Related Answers
Anonymous
  • 105 Answers
  • Posted on Feb 24, 2008
SOURCE: bosch classixx dishwasher not draining
try removing pump some models can be serviced fron inside well of machine glass can stop the pump from turning
clean out water and remove filters find a screw in base of well remove and remove pump housing check with torch to see if any obstuctions there if not see if the impellor moves around when turned and make shure that the pump is not worn out
Anonymous
  • 3 Answers
  • Posted on Apr 27, 2009
SOURCE: Dishwasher does not drain, instead drains through overflow valve in sink. No apparent clog seen.
Usually the sink connection is not an overflow, it is the main drain from the dishwasher. It is more likely your s-bend is blocked under the sink- try putting a bucket under it and unscrewing the u-shaped piece and cleaning out (remember don't wash it in that sink while the pipe is off)
Mukesh Kumar
  • 3230 Answers
  • Posted on May 06, 2009
SOURCE: lg - LDS5811ST Dishwasher OE Error Code
hi
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
Anonymous
  • 784 Answers
  • Posted on Sep 13, 2009
SOURCE: dishwasher doesn't drain completely after full cycle
If there is any blockage in your diposal, water will comes up to the sink, since it happened to me. As soon I installed the air gap then it fixed the problem. No air gap, water flowing is slowing down conflicting with timed draining causing this problem. Let's think of this, if you fill up water in a 1/2 galon milk container, and you try to emty it. If you pull down straightly , it will be slow compared to pull it at an agle to let air going into the opening. The air vent helps water flow better meeting the timed draining.
Anonymous
  • 4323 Answers
  • Posted on Aug 30, 2011
SOURCE: Dishwasher won't drain when cycle
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
The one way flapper in the drain pump has broken off.
Maytag dishwasher won't drain
Drainage problem of some sort is usually the cause. Could be blockage before your drain pump, in your drain pump, or in your drain hose. One possibility is that you just installed a garbage disposal and forgot to remove the "knock-out" plug for the dishwasher drain line. Another cause can be that you have not looped your dishwasher drainline under your sink and water from your sink is flowing back into you dishwasher. You must attach your dishwasher drain line under your sink so it is higher then your sink drain lines, creating a trap for your dishwasher. Your drain sump could be plugged, not letting the water get to your drain pump easily. This is caused by not getting loose or hard debris off your dishes before putting them in the unit. Also make sure your drain pump is getting the right voltage when it is supposed to.God bless youfa618d8b-d0fd-412a-b0d5-a88d44bf89d3.giffb1320dc-7bec-4cb0-98ed-c24cf54e5e3b.jpg
Apr 02, 2013 • Dishwashers
2helpful
I have built in GE Cafe series dishwasher, stainless steel. Quite often it will leave dirt and residual food on dishes. What do I need to look at and/or what fix is there?
In case you do not have the user manual you can download from this site.
Refer page 18 for possible causes of unclean dishes. More often than not it is the drain filter or the kitchen sink drain outlet that is clogged. If you are using a garbage disposer in kitchen sink then make sure it is run before you start the dishwasher.
Hope this helps.
4helpful
3answers
Miele G646SC Plus dishwasher Drainage / inlet warning light
If the unit doesn't drain properly check for any kinked hoses and also check the drain spigot under the sink where the drain hose goes into the sink as these are not always opened up enough for the water to escape and a slight shoulder can then trap food particles and cause a blockage.
As for the base tray getting water inside the unit check inside the cabinet to make sure the top spray arm lock nut is tight and the ring on the side of the unit is not loose inside the cabinet where the water enters the unit. These two things can cause water to run down the side panels and into the base. The black hose i think is the overflow pipe. Also make sure you are not using too much detergent and the correct detergent as this can over sud and water can spill into the base. Hope this helps.
1helpful
It all started when garbage disposal went out. dishwasher filled
no but keeping hte screens anddrains clear will, no real majic answer here ohter then taking apart and lookin for the blockage
GE Triton XL, Dishwasher, while washing dishes in the sink
Ho could be a blockage in the dishwaser pump, is the drain plug clear .............
Top GE Dishwashers Experts
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
